Home > Forums > Software User Forums > Fidelity CFD
AutoBlade for airfoils??
Old   July 11, 2003, 16:18
Default AutoBlade for airfoils??
Steve
Greetings,
I am trying to create standard airfoil sections in AutoBlade (e.g. C-Series parabolic arc camberline and NACA 65-Series). I realize the code does not have these definitions explicitly. However, I was wondering if anybody out there has created these (or other standard airfoils) using the parameters available so I don't have to reinvent the proverbial wheel.
Old   August 2, 2003, 09:47
Default Re: AutoBlade for airfoils??
joe
u'd better use the Desing3D module of NUMECA, it can design a parameter airfoil sections, then u can import a target file which is contact your NACA 65-Series to fitting the parameter airfoil !
Old   August 4, 2003, 09:45
Steve
Thank you Joe, good thought. This one has actually been suggested to me earlier. My hesitation with this is that it requires redundant definition of the problem, i.e., · find airfoil geometry generation tool that can provide surface coordinates given camber, thickness distribution, and LE & TE radius · convert this to .geomTurbo format · import to AutoBlade · perform fitting to recover parameters · export back to .geomTurbo format
This would be a good approach if I know that I was going to go through substantial parametric design effort via AutoBlade and Fine/Turbo. However, in this case, my blades are loaded well within typical range of the 65-series airfoils (in cascade) and I am more interested in quantifying off-design performance.
I have thought about trying this approach to recover some "base" parameters to then use for a family of airfoils. However, the control of camber and thickness distributions is touchy enough already that I fear it would not be generally applicable to obtain expected shapes.
What do you think – have you tried this?
Help for Autoblade Fitting stewart Fidelity CFD 15 July 7, 2012 08:01
AUTOGRID and AUTOBLADE strengths and limitations Haider Fidelity CFD 1 December 6, 2007 20:24
help:AUTOBLADE haider Fidelity CFD 3 July 2, 2007 02:25
Low Re Airfoils Chan Main CFD Forum 0 September 23, 2003 21:22
Airfoils D. Brown FLUENT 5 April 19, 2000 12:14
