August 27, 2008, 04:06 |
Memory allocation failed ???
Hi, all,
The Memory Allocation Failed message comes out when I start a run. 1.42 GB is needed which is indicated from the control variables panel. My computer is configured as 4 GB of physical memory, and with 32-bit Windows XP platform. The needed memory is below the 2GB limitation of the 32-bit system. Why this happend? I terminated all other applications when I running the model. In addition, the version of FINE is 74_1. Anybody encountered this before? And how do you overcome it? Many thanks! Rikio |
August 30, 2008, 08:47 |
Re: Memory allocation failed ???
that is craps for Numeca, this happen to us also a lot, especially for non-linear harmonic unsteady simulation.
i dont know to deal with that either, but my advisor has wrote a script in Linux to start the solution everytime manuelly, the memory is also manuelly allocated. sometimes, it works, sometime it not, then we just have to try till it is just right |
August 30, 2008, 12:28 |
Thanks for your reply, Jesse.
Is there any difference between specifing memory allocation through script and GUI of FINE? What have been changed via the script? If you will, we can have further communication through E-mails. Thank you again. Rikio |
September 2, 2008, 06:03 |
i am sorry, i have to correct something,
it isnot that we assign the memory and start the computation manually via scripts(of course, we can also do that), but the thing is, my advisor hat wrote a script to calculate how much momery it requires to run the simulation on multiprocessors, and compare to the physical memory you have to see if it is large enough and if you can run it successfully. the script itself i can not attach here, but here is the general procedure. check the requested memory under control variables, marked down the real and integer memory demanding, via the formular in fineturbo usermanual page 347 you can calcuate the actually requred memory compared to the physical memory you have to see if it is enough. for harmonic simulation, the memory calculation is more complicated, i still have no clue how the transformation works. hope it will help you in someway |
memory allocation error | MAB | CFX | 16 | December 30, 2014 20:59 |
memory allocation failed | Li Yijin | Fidelity CFD | 3 | January 29, 2008 21:42 |
Memory allocation problem | Ammar Abdilghanie | FLUENT | 5 | February 19, 2007 18:15 |
Memory Allocation | Harish | Main CFD Forum | 0 | July 26, 2005 15:29 |
memory allocation | strudl | CFX | 1 | October 5, 2003 10:26 |
