Home > Forums > OpenFOAM Bugs
calculation of kappa in buoyantBoussinesqPimpleFoam
Old   November 6, 2012, 08:52
Default calculation of kappa in buoyantBoussinesqPimpleFoam
yosuu is on a distinguished road
Hello Foamers!
I have discovered a serious bug (in my opinion) in the buoyantBoussinesq solvers (version 2.1.1). I checked how the kappa is implemented, and i have my doubts that it is correctly done.
In the original code is:
kappat = turbulence->nut()/Prt;
kappat.correctBoundaryConditions();
volScalarField kappaEff("kappaEff", turbulence->nu()/Pr + kappat);
but i think that there should be a Cp multiplying the kappa terms, so the final code
kappat = Cp*turbulence->nut()/Prt;
volScalarField kappaEff("kappaEff", Cp*turbulence->nu()/Pr + kappat);
because from definition of Prt=nut/alphat=nut*Cp*rho/kappa. Since the equations are incompressible, that ends up as Prt=nut*Cp/kappa.
Note: to make it work, Cp must be added in readTransportProperties.H from buoyantBoussinesqSimpleFoam.
What do you think about it? When I run laminar cases, it takes forever to see the temperature field to change from the initial condition when using the original code.
yosuu is offline   Reply With Quote
Old   November 6, 2012, 09:53
ok, i might have been wrong all the time. So, kinematic thermal conductivity is not the same as normal thermal conductivity coefficient...
Thread Tools
Trackbacks are On
Help! Questions on Boundary Layer Spring Method for 3D Calculation didiean FLUENT 13 June 28, 2012 02:47
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 08:46
Transfer output data as input for second calculation mannobot Main CFD Forum 1 June 2, 2010 03:55
Warning 097- AB CD-adapco 6 November 15, 2004 04:41
Heat Flux Calculation under REPORTS Alberto Schroth FLUENT 0 May 16, 2000 08:19
