ParaView: Number of cells/points in mesh and field don't match |
December 5, 2012, 08:54 |
Fergus
Hi guys,
Running the incompressible motorBike tutorial with ./Allrun I can view the mesh OK but when I click 'play' or scroll through the time bar to try to view pressure, velocity contours etc I'm getting error messages: Code:
ERROR: In /home/opencfd/OpenFOAM/ThirdParty-2.1.x/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6481 vtkOpenFOAMReaderPrivate (0x2c71c50): Error reading line 22 of /home/fergus/OpenFOAM/fergus-2.1.1/run/tutorials/incompressible/simpleFoam/motorBike/0/U: Expected number, string or (, found flowVelocity ERROR: In /home/opencfd/OpenFOAM/ThirdParty-2.1.x/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6481 vtkOpenFOAMReaderPrivate (0x2c71c50): Error reading line 21 of /home/fergus/OpenFOAM/fergus-2.1.1/run/tutorials/incompressible/simpleFoam/motorBike/0/k: Expected number, string or (, found turbulentKE ERROR: In /home/opencfd/OpenFOAM/ThirdParty-2.1.x/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6882 vtkOpenFOAMReaderPrivate (0x2c71c50): boundaryField motorBike_frt-fairing:001%1 not found in object nut at time = 0 ERROR: In /home/opencfd/OpenFOAM/ThirdParty-2.1.x/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6481 vtkOpenFOAMReaderPrivate (0x2c71c50): Error reading line 21 of /home/fergus/OpenFOAM/fergus-2.1.1/run/tutorials/incompressible/simpleFoam/motorBike/0/omega: Expected number, string or (, found turbulentOmega ERROR: In /home/opencfd/OpenFOAM/ThirdParty-2.1.x/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6481 vtkOpenFOAMReaderPrivate (0x2c71c50): Error reading line 21 of /home/fergus/OpenFOAM/fergus-2.1.1/run/tutorials/incompressible/simpleFoam/motorBike/0/p: Expected number, string or (, found pressure ERROR: In /home/opencfd/OpenFOAM/ThirdParty-2.1.x/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6589 vtkOpenFOAMReaderPrivate (0x2c71c50): Number of cells/points in mesh and field don't match: mesh = 343673, field = 1280 ERROR: In /home/opencfd/OpenFOAM/ThirdParty-2.1.x/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6589 vtkOpenFOAMReaderPrivate (0x2c71c50): Number of cells/points in mesh and field don't match: mesh = 343673, field = 1280 ERROR: In /home/opencfd/OpenFOAM/ThirdParty-2.1.x/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6589 vtkOpenFOAMReaderPrivate (0x2c71c50): Number of cells/points in mesh and field don't match: mesh = 343673, field = 1280 Any tips? [OF2.1.1 on Ubuntu 12.04 hosted on Win7] |
March 1, 2017, 09:06 |
Could you find any solution for this problem?
#3 | |
Rep Power: 9 |
Hi jaggy, I have this problem after these years, Could you find any solution for this problem?
[snappyHexMesh] Number of cells/points in mesh and field don't match | kd55 | OpenFOAM Meshing & Mesh Conversion | 20 | March 11, 2024 06:54 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
