December 18, 2012, 09:28 |
bug with alpha1 time dependant boundary
Simon Arne
Rep Power: 13 |
Hi there,
I implement the following BC instead of fixedValue 1: Code:
inlet { type uniformFixedValue; uniformValue table ( ( 0 1) ( 0.01 1) (0.1 1) ); } Code:
[0] [0] [0] --> FOAM FATAL ERROR: [0] object is not allocated [0] [0] From function const T& Foam::autoPtr<T>::operator()() const [0] in file /home/preston2/mattijs/rpmbuild/BUILD/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/autoPtrI.H at line 132. [0] FOAM parallel run aborting I think there is a small bug in there but as I dont really need this boundary I dont investigate further. It's openFoam 2.1.0 with parallel interfoam. Sorry if it is already fixed, I had a look in the bug reporting system but I am super busy so maybe I overlooked it. Greetings, Simon |
December 22, 2012, 15:05 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Simon,
Since you wrote that you were busy, I've made a test case and checked with the latest 2.1.x and the error does still occur. The report has been made here: http://www.openfoam.org/mantisbt/view.php?id=709 edit: And 1h later it's already fixed! Best regards, Bruno
December 22, 2012, 17:49 |
Simon Arne
Rep Power: 13 |
Hey,
Thanks for cleaning it up! I am not sure if it is related, but when I put a flowRate with time-table for U condition in the same case, it crashes as well (interFoam, 2.1.0, parallel). Well if I find the logfile somewhere I put it in here. Just about to finish my thesis, things go crazy here. Greetings, Simon |
December 24, 2012, 14:37 |
Bruno Santos
Rep Power: 128 |
Hi Simon,
I've tested in the tutorial "multiphase/interFoam/laminar/damBreak" to modify in the "0/U" file the "leftWall" entry to this: Code:
leftWall { type flowRateInletVelocity; flowRate 0.02; // Volumetric/mass flow rate [m3/s or kg/s] value uniform (0 0 0); // placeholder } Code:
blockMesh cp 0/alpha1.org 0/alpha1 setFields decomposePar foamJob -s -p interFoam With 2.1.1, it was complaining about some "adjoint" thingy when running decomposePar, which is (probably) already fixed in 2.1.x. Maybe the force be with you to finish the PhD on time! Best regards, Bruno
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
InterFoam negative alpha | karasa03 | OpenFOAM | 7 | December 12, 2013 03:41 |
Interfoam blows on parallel run | danvica | OpenFOAM Running, Solving & CFD | 16 | December 22, 2012 02:09 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
