Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
ParaView Error messages when accessing View menu
Old   June 18, 2012, 06:08
Default ParaView Error messages when accessing View menu
Alexey Boltaks
Wormer is on a distinguished road
Dear Forum,
I'm using Paraview 3.12.0 (64 bit), and every time I go to the program's view menu, the program pops up a window full of error messages of a following syntax:
p, li { white-space: pre-wrap; } [31mvoid DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Main Controls" under id 66
Now, the only inconvenience is the fact that this window pop interrupts the work flow. I haven't noticed (so far) any effect on the other features of the program, but it's still annoying.
Is there any way around it?
Thanks in advance,
Alexey B.
Wormer is offline   Reply With Quote
Old   June 18, 2012, 15:48
Retired Super Moderator
Bruno Santos
Hi Alexey,
It would help to know which installation you've made of OpenFOAM and on which Operating System, along with respective versions, so it's easier to reproduce the error.
Best regards,
Bruno
Old   June 19, 2012, 07:51
Alexey Boltaks
Dear Bruno: you're right!
It's the 2.1.0 version of OpenFOAM along with 12.04 version of Ubuntu.
The error shows up everytime I go to the view menu of ParaView.
Thanks in advance,
Alexey B.
Old   June 19, 2012, 16:55
Bruno Santos
Hi Alexey,
After I did some googling about this, I found this bug report: https://bugs.launchpad.net/ubuntu/+s...ew/+bug/995949 - looks like you're not alone.
Another thing I found was that a couple of people had this issue on Ubuntu 11.10... but didn't find a direct fix, except for installing another version of ParaView, i.e. use another pre-built binary.
There are a few possibilities for this kind of error... but now that I think of it, hold on: OpenFOAM 2.1.0?
Are you using Ubuntu deb packages or did you build from source? Because I think that only OpenFOAM 2.1.1 is supported on Ubuntu 12.04, when using the deb packages: http://www.openfoam.org/download/ubuntu.php
As for ParaView, which exact instructions did you follow to install it?
Best regards,
Bruno
Old   December 1, 2012, 22:55
haze_1986 is on a distinguished road
Originally Posted by wyldckat View Post
Hi Alexey,
Best regards,
Bruno
Hi Bruno,
I would just like to add that I have the exact same problem as well when using ubuntu 12.04 LTS on vbox. using of 2.1.1 and paraview 3.1.2, using http://www.openfoam.org/download/ubuntu.php
Is there a way to fix this?
haze_1986 is offline   Reply With Quote
Old   December 1, 2012, 22:56
Output Messages
[31mvoid DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Main Controls" under id 62
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Selection Controls" under id 63
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "VCR Controls" under id 64
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Current Time Controls" under id 65
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Active Variable Controls" under id 66
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Representation Toolbar" under id 67
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Camera Controls" under id 68
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Center Axes Controls" under id 69
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Macros Toolbars" under id 70
Old   December 2, 2012, 06:48
Bruno Santos
Greetings haze_1986,
Do you have 3D acceleration turned on in the virtual machine's settings? If you do, try turning them off. You'll probably need to turn off the virtual machine, configure the settings and turn it back on.
Best regards,
Bruno
Old   December 2, 2012, 06:52
Best regards,
Bruno
Hi, just tried it. still the same error.
Old   December 2, 2012, 10:20
Bruno Santos
Which architecture of Ubuntu did you install? 32bit or 64bit?
You can check by running:
uname -m
edit: Furthermore, make sure to update all of Ubuntu's packages:
sudo apt-get update
sudo apt-get upgrade
Old   December 2, 2012, 10:26
uname -m
sudo apt-get update
64 bit
yes I ve updated them frequently. This problem had been there for almost half a year already, just that not serious enough to prevent me from using it. Now that I have some time, would really wanna try to fix that.
Old   December 2, 2012, 11:01
Bruno Santos
I've got Ubuntu 12.04 64bit installed in a virtual machine as well, but with VMPlayer. I've installed OpenFOAM 2.1.1 and ParaView 3.12.0 with the Deb packages provided at openfoam.org. It's fully up-to-date. I've also installed Ubuntu's own ParaView...
But I'm unable to reproduce the same problem. You can try checking with:
qmake --version
To see if it output's this:
QMake version 2.01a
Using Qt version 4.8.1 in /usr/lib/x86_64-linux-gnu
Well, that is only the tip of the iceberg. My guess is that you might have installed something else as well that has thrown the system off and giving you these errors. I know these aren't new, because I've seen them around the net several times before. But they seem to usually be fixed after updating the system.
There are a few possibilities I can think of:
  1. If you installed some other CAE software, possibly older, it might be contaminating the working shell environment, which leads to the errors you're getting.
  2. You might have disabled one or more repositories, leading to necessary packages not be updated. Or the other way around, enabled repositories that installed unstable or older packages.
  3. It could also be VirtualBox's fault, because it's known to have the occasional crazy bug that is only fixable with a particular version...
  4. If you upgraded Ubuntu 12.04 from 11.10, something might have gotten broken along the way.
Best regards,
Bruno
Old   December 2, 2012, 20:52
qmake --version
QMake version 2.01a
Best regards,
Bruno
Hi Bruno,
QMake version 2.01a
I tried a clean install in another pc and I am able to replicate the problem, in fact, up till today I have tried in 2 of my home PCs and 2 of my company PCs and all have that problem. And the last one is a clean install, bare system only with OF and paraview installed.
Old   December 3, 2012, 09:56
just gotten the same exact error on vmware player fresh install. I might wanna try using another version of paraview next.
Old   December 3, 2012, 16:04
Bruno Santos
Hi haze_1986,
I've written some instructions the other day, that I forgot to reference here: http://www.cfd-online.com/Forums/ope...tml#post395266 post #6
Hopefully those will help you isolate the problem.
Good luck!
Bruno
Old   December 3, 2012, 22:10
Not really sure about that since I am installing on 12.04LTS. I have just tried using the script install on a fresh system still the same thing. I wonder and it seems that there is something that I missed out after installing ubuntu in virtualbox that the rest of you not getting the error had. All I did was install ubuntu, do a full update, install guest additions, then openfoam and paraview.
Old   December 4, 2012, 07:18
compiling everything solved the problem, no more errors under view
http://openfoamwiki.net/index.php/In...u#Ubuntu_12.04
I supposed we can just compile paraview, but I compiled for both since I wanna try it once.
Old   December 4, 2012, 16:14
Bruno Santos
Hi haze_1986,
I'm glad you've finally got things working and that you shared the working solution!
I should have proposed that solution earlier, but I also wanted to figure out why the original problem was occurring .
Best regards,
Bruno
Old   December 5, 2012, 08:08
Fergus
Jaggy_Snake is on a distinguished road
Quick shout to say I've been having the same problem as above on OF 2.1.1 & Paraview 3.12.0 on ubuntu 12.04 (Win7 host on virtualbox 4.2.4)
Trying to (re?)install Paraview using:
 cd $WM_THIRD_PARTY_DIR
./makeParaView
cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers
wmSET $FOAM_SETTINGS
./Allwclean
./Allwmake
But when I try to change directory it says:
bash: cd: WM_THIRD_PARTY_DIR: No such file or directory
Am I doing something stupid?
Jaggy_Snake is offline   Reply With Quote
Old   December 6, 2012, 07:55
Bruno Santos
Originally Posted by Jaggy_Snake View Post
You simply forgot to use the $ symbol
Old   December 6, 2012, 22:04
Fergus
Perhaps I was missing the $, however I still get the following.
bash: cd: /opt/ThirdParty-2.1.1: No such file or directory
My folder ThirdParty-2.1.1 is located at ~/OpenFOAM/ThirdParty-2.1.1 and my OpenFOAM-2.1.1 folder is at ~/OpenFOAM/OpenFOAM-2.1.1
It seems my ThirdParty folder is maybe in the wrong location?
Thanks
[OpenFOAM] How to view openfoam results in paraview Marineboy ParaView 9 June 19, 2019 21:16
[OpenFOAM] View grid coordinates in Paraview ozzythewise ParaView 3 June 6, 2017 04:12
[General] Paraview User defined view prapanj ParaView 3 January 3, 2014 20:54
[OpenFOAM] ParaView 3.6.1 & 3.7.0: Can't view STL files johannes ParaView 2 December 3, 2009 14:07
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
