February 9, 2012, 05:01 |
aachenBomb with sprayFOAM not working
Jens Keller
Rep Power: 14 |
why is the aachenBomb tutorial with the solver sprayFOAM in OpenFOAM 2.1.x not working? I have updated my Foam version today! At first OpenFOAM tells me that: Code:
keyword massFlowRate is undefined in dictionary run/tutorials/lagrangian/sprayFoam/aachenBomb/constant/sprayCloudProperties::subModels::coneNozzleInjectionCoeffs Code:
massFlowRate 1e-3; Code:
#0 Foam::error::printStack(Foam::Ostream&) in "/home/XXX/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigSegv::sigHandler(int) in "/home/XXX/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib64/libc.so.6" #3 Foam::cachedRandom::scalar01() in "/home/XXX/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 Foam::ConeNozzleInjection<Foam::KinematicCloud<Foam::Cloud<Foam::SprayParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > > >::ConeNozzleInjection(Foam::dictionary const&, Foam::KinematicCloud<Foam::Cloud<Foam::SprayParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > >&) in "/home/XXX/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/liblagrangianSpray.so" #5 Foam::InjectionModel<Foam::KinematicCloud<Foam::Cloud<Foam::SprayParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > > >::adddictionaryConstructorToTable<Foam::ConeNozzleInjection<Foam::KinematicCloud<Foam::Cloud<Foam::SprayParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > > > >::New(Foam::dictionary const&, Foam::KinematicCloud<Foam::Cloud<Foam::SprayParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > >&) in "/home/XXX/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/liblagrangianSpray.so" |
February 9, 2012, 11:58 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Jens,
The git version isn't always very stable. They made some changes to the git version, which affects that tutorial, namely this one: https://github.com/OpenFOAM/OpenFOAM...9e9c33a0fbe341 I think the related change is being tracked here: http://www.openfoam.com/mantisbt/view.php?id=407 - you can properly complain there Best regards, Bruno
February 9, 2012, 12:30 |
Marco A. Turcios
Rep Power: 28 |
I'm the one who has reported on the issue. I guess the tutorial case hasn't been updated to reflect the changes. I've uploaded a sprayCloudProperties that works with the current version of sprayFoam (tested this morning), just copy it over and remove the extension.
There are a lot of new entries that I'm still figuring out. Mainly I'd like to know what the constantProperties part of the file defines for the parcels. Still looking for answers, will post when I find anything of note. EDIT: I'd performed some limited testing and it appears that rho0,T0 and Cp0 are the properties of parcels as they are introduced into the domain. As the file currently stands, the r0, cp0 are for water at atmospheric pressure and T0. The dieselSpray class used to pull the properties from whatever liquid you were injecting at the stated conditions automatically. I'm still figuring out what properties get used where, as I think it would be better to obtain properties from liquidProperties. Last edited by mturcios777; February 9, 2012 at 14:23. |
February 11, 2012, 04:05 |
Niklas Nordin
Rep Power: 29 |
i dont understand why you need to define massFlowRate, it looks like
you have some old files still hanging around. If you do you can get some weird effect. Have you done clean in lagrangian/intermediate and then wake libso? still, I think you need to give it at keyword before the value. Like massFlowRate constant 1.0; |
February 13, 2012, 03:54 |
#5 | |
Jens Keller
Rep Power: 14 |
it works now! |
May 15, 2014, 02:16 |
raviteja
Could you please tell tell me ,how to specify the injection pressure in sprayfoam aachen box example. There was an option in dieselFoam, But i dont find it in sprayfoam.
June 5, 2014, 14:07 |
yes
Rep Power: 12 |
Dear Marco
I read a post from you days ago about the changes that appear in sprayFoam and I have the same question that Raviteja, I need to change the injection pressure, where is that value or how can I add to the spray properties?. I use the OpenFoam wiki about injection pressure but they make reference about the dieselFoam solver, where you can easily change the injection pressure, and add a line with the scalar value as set in the coneNozzleinjector.C. duration 1.2e-3; position ( 0 0.0795 0 ); direction ( 0 -1 0 ); //..Pressure added injectionPressure 800.0e+5; Really running out of ideas. Any advice will be very gratefully. Thanks a lot Kind regards |
June 6, 2014, 13:18 |
Marco A. Turcios
Rep Power: 28 |
You should use the coneNozzleInjection injector model, which should give you access to a parameter called Pinj which is the injection pressure.
June 8, 2014, 18:01 |
#9 |
yes
Rep Power: 12 |
Thanks a lot my friend I'm also change to pressureDrivenvelocity
King regards |
sprayfoam |
DPM parallel is not working but serial is working | johnwinter | FLUENT | 1 | March 27, 2012 02:01 |
ICEM working directory setting | Bogesz | CFX | 2 | October 8, 2008 07:45 |
Working Principle of Micro-Oven | aero | Siemens | 2 | January 31, 2007 05:00 |
Help required on working of Micro-oven | aero | CFX | 4 | January 19, 2007 08:21 |
Help required on working of Woven | aero | FLUENT | 0 | January 16, 2007 06:25 |
