Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
MergeMeshes with version OF14
Like Tree4Likes
  • 4 Post By wikstrom
Old   August 23, 2007, 15:35
Default Description: Problem in OF-1.
Jens Klostermann
jens_klostermann is on a distinguished road
Description:
Problem in OF-1.4.1
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4.1 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : mergeMeshes . testcase . temp
Date : Aug 23 2007
Time : 21:16:54
Host : pc076
PID : 24068
Root :
Case :
Nprocs : 1
Master: "." "testcase"
mesh to add: "." "temp"
Create Times
Reading master mesh for time = 0
Create mesh
Reading mesh to add for time = 0
Create mesh
--> FOAM FATAL ERROR : Attempt to cast type mergePolyMesh to type fvMesh#0 Foam::error::printStack(Foam:stream&) in "/home/klosterm/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/klosterm/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::probes::read(Foam::dictionary const&) in "/home/klosterm/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libsampling.so"
#3 Foam::probes::probes(Foam::objectRegistry const&, Foam::dictionary const&) in "/home/klosterm/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libsampling.so"
#4 Foam::probesFunctionObject::start() in "/home/klosterm/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libsampling.so"
#5 Foam::functionObjectList::start() in "/home/klosterm/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#6 Foam::Time::operator++() in "/home/klosterm/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#7 main in "/home/klosterm/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/mergeMe shes"
#8 __libc_start_main in "/lib/libc.so.6"
#9 __gxx_personality_v0 at /build/buildd/glibc-2.3.6/build-tree/glibc-2.3.6/csu/../sysdeps/x86_64/elf/start .S:116
From function refCast<to>(From&)
in file /home/klosterm/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/typeInfo.H at line 103.
FOAM aborting
Aborted (core dumped)
Problem in OF-1.4
| \ / O peration | Version: 1.4 |
Date : Aug 23 2007
Time : 21:18:24
Host : pc076
PID : 24463
Root :
Case :
Nprocs : 1
Create Times
Selecting function probes
--> FOAM Warning :
From function dlLibraryTable::open(const dictionary& dict, const word& libsEntry, const TablePtr tablePtr)
in file lnInclude/dlLibraryTableTemplates.C at line 67
library "libsampling.so" did not introduce any new entries
Create mesh
Create mesh
#7 main
in file /home/klosterm/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude/typeInfo.H at line 103.
FOAM aborting
Solver/Application:
mergeMeshes
Platform:
64bit linux (Debian), but I think it doesn't matter
Version:
OF-1.4 and OF-1.4.1
Notes:
It always a good idea to have an old version, because it works (on the same case and platform) with the OF-1.3 Hrv version without any problems.
| \ / O peration | Version: 1.3 |
Date : Aug 23 2007
Time : 21:18:37
Host : pc076
PID : 24723
Root :
Case :
Nprocs : 1
Create Times
Create mesh
Create mesh
Writing combined mesh to 2e-05
patch names:
8
OUTLET_FACE
INLET_FACE
AUSLAUF_1_10
EINLAUF_1_14
SL_LINKS
SL_RECHTS
AUSLAUF_OHNE_FS
CLOSE_AUSSEN
patch types:
8
wall
wall
wall
wall
wall
wall
wall
wall
point zone names:
0
face zone names:
0
cell zone names:
1
SOLID
jens_klostermann is offline   Reply With Quote
Old   January 28, 2009, 04:28
Default This problem seems to remain i
Niklas Wikstrom
wikstrom is on a distinguished road
This problem seems to remain in version 1.5.x, BUT in my case it probably has to do with the creation of functionObjects. When these are removed from the controlDicts, it works OK.
regards
Niklas
wikstrom is offline   Reply With Quote
Old   November 7, 2014, 16:27
Default thanks
Baek, Donghae
wes1204 is on a distinguished road
really thank to you
I struggle with same problem for 3 days.
the problem was solved with deleting function in controldict.
wes1204 is offline   Reply With Quote
[mesh manipulation] MergeMeshes hsieh OpenFOAM Meshing & Mesh Conversion 3 September 10, 2014 09:15
[mesh manipulation] MergeMeshes and stitchMesh problem flo OpenFOAM Meshing & Mesh Conversion 6 May 10, 2010 10:40
MergeMeshes and mesh format from 14x 15 pitmanm OpenFOAM Bugs 14 July 4, 2009 00:55
MergeMeshes fails on OF141 any fix hsieh OpenFOAM Bugs 3 January 29, 2008 19:31
PROBLEMS WITH cfdTools in OF14 leosding OpenFOAM Running, Solving & CFD 1 August 20, 2007 13:05
