March 4, 2015, 06:49 |
foam-3.1 and openmpi 1.8.1
Rep Power: 16 |
I faced performance problem with system mpi (rhel6.6). A mpi version is 1.8.1 and latest source of the foam 3.1 is used. If on the same computer is running a one case everything works fine and performance is better than mpi 1.6.5. Performance dropping dramatically if I put other case to run by parallel. Looking at cpu load by "top" %CPU is only 50% and if the third case is put to running CPU load drop to 33.3%. So, from some reason cpus load is scaled by number of running task. This not happen by older mpi version. Is it foam or mpi bug? or can it solve by some parameters? Thanks BR/Pekka |
Display Modes | |
[OpenFOAM.org] mpirun not working in paralleö with OpenMPI | zordiack | OpenFOAM Installation | 15 | October 5, 2017 21:45 |
openmpi and "executable not found" | bgoeppner | OpenFOAM | 1 | April 1, 2010 07:51 |
HOW TO RUN FOAM WITH MPICH | waynezw0618 | OpenFOAM Running, Solving & CFD | 5 | May 13, 2009 08:21 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
