Bug in myinterFoamDiabatic
Old   July 28, 2016, 04:36
Question Bug in myinterFoamDiabatic
Rayan CFD is on a distinguished road
when i followed the steps of (http://www.tfd.chalmers.se/~hani/kur...gLIU-final.pdf) to implement thermal diffusion-convection in the interFoam solver i have this error. The solver and the libraries have been compiled well (wmake libso and wmake). But when i run a test case i have this error. I modified also the syntax of the code because i work on OpenFoam 3.0.1
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field T
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Reading / calculating rho*cp
Reading / calculating rho*phi*cp
Selecting turbulence model type laminar
Reading g
Reading hRef
Calculating field g.h
No MRF models present
No finite volume options present
DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
time step continuity errors : sum local = 0, global = 0, cumulative = 0
Courant Number mean: 0 max: 0
Starting time loop
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigSegv::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam:bjectRegistry::modified() const at ??:?
#4 Foam:bjectRegistry::modified() const at ??:?
#5 Foam::Time::readModifiedObjects() at ??:?
#6 Foam::Time::run() const at ??:?
#7 ? at ??:?
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9 ? at ??:?
Erreur de segmentation (core dumped)
Thank you
Rayan CFD is offline   Reply With Quote
bug, interfoam, run-case, thermal
Bug in Workbench CFX Pierre1 CFX 6 August 2, 2017 00:18
SU2_MSH: Periodic boundary conditions bug Zef SU2 1 February 18, 2015 13:28
Serious bug in LES interface fs82 OpenFOAM Bugs 21 November 16, 2009 08:15
Bug reports Mattijs Janssens (Mattijs) OpenFOAM 0 January 10, 2005 10:05
Forum y2k Bug Jonas Larsson Main CFD Forum 1 January 5, 2000 10:22
