-   OpenFOAM Bugs (http://www.cfd-online.com/Forums/openfoam-bugs/)
-   -   Bug in GeometricScalarFieldC (http://www.cfd-online.com/Forums/openfoam-bugs/62308-bug-geometricscalarfieldc.html)
prjohnston February 19, 2009 03:07
Hello, With the help of Ber
With the help of Bernhard, we tracked down a bug in GeometricScalarField.C in relation to the pow function. Line 157 reads:
dimensionedScalar("1", 1.0, gsf2.dimensions())
but should read
dimensionedScalar("1", gsf2.dimensions(), 1.0)
The same comments apply to lines 186 and 217.
Regards,
Peter
henry February 19, 2009 03:59
Thank you very much for the bu
Thank you very much for the bug report. This error is a legacy from when I changed the order of the constructor arguments to make dimensionedType more consistent with the rest of the code. I will push the corrected version to 1.5.x shortly.
H
hyperion December 11, 2010 15:35
Hi I am having trouble with the pow function with volScalarField as an argument. Would this be a related problem?
Thanks
