-   OpenFOAM Bugs (http://www.cfd-online.com/Forums/openfoam-bugs/)
-   -   MergeMeshes with version OF14 (http://www.cfd-online.com/Forums/openfoam-bugs/62332-mergemeshes-version-of14.html)
jens_klostermann August 23, 2007 15:35
Description: Problem in OF-1.
Description:
Problem in OF-1.4.1
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4.1 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : mergeMeshes . testcase . temp
Date : Aug 23 2007
Time : 21:16:54
Host : pc076
PID : 24068
Root :
Case :
Nprocs : 1
Master: "." "testcase"
mesh to add: "." "temp"
Create Times
Reading master mesh for time = 0
Create mesh
Reading mesh to add for time = 0
Create mesh
--> FOAM FATAL ERROR : Attempt to cast type mergePolyMesh to type fvMesh#0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) in "/home/klosterm/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/klosterm/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::probes::read(Foam::dictionary const&) in "/home/klosterm/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libsampling.so"
#3 Foam::probes::probes(Foam::objectRegistry const&, Foam::dictionary const&) in "/home/klosterm/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libsampling.so"
#4 Foam::probesFunctionObject::start() in "/home/klosterm/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libsampling.so"
#5 Foam::functionObjectList::start() in "/home/klosterm/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#6 Foam::Time::operator++() in "/home/klosterm/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#7 main in "/home/klosterm/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/mergeMe shes"
#8 __libc_start_main in "/lib/libc.so.6"
#9 __gxx_personality_v0 at /build/buildd/glibc-2.3.6/build-tree/glibc-2.3.6/csu/../sysdeps/x86_64/elf/start .S:116
From function refCast<to>(From&)
in file /home/klosterm/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/typeInfo.H at line 103.
FOAM aborting
Aborted (core dumped)
Problem in OF-1.4
| \ / O peration | Version: 1.4 |
Date : Aug 23 2007
Time : 21:18:24
Host : pc076
PID : 24463
Root :
Case :
Nprocs : 1
Create Times
Selecting function probes
--> FOAM Warning :
From function dlLibraryTable::open(const dictionary& dict, const word& libsEntry, const TablePtr tablePtr)
in file lnInclude/dlLibraryTableTemplates.C at line 67
library "libsampling.so" did not introduce any new entries
Create mesh
Create mesh
#7 main
in file /home/klosterm/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude/typeInfo.H at line 103.
FOAM aborting
Solver/Application:
mergeMeshes
Platform:
64bit linux (Debian), but I think it doesn't matter
Version:
OF-1.4 and OF-1.4.1
Notes:
It always a good idea to have an old version, because it works (on the same case and platform) with the OF-1.3 Hrv version without any problems.
| \ / O peration | Version: 1.3 |
Date : Aug 23 2007
Time : 21:18:37
Host : pc076
PID : 24723
Root :
Case :
Nprocs : 1
Create Times
Create mesh
Create mesh
Writing combined mesh to 2e-05
patch names:
8
OUTLET_FACE
INLET_FACE
AUSLAUF_1_10
EINLAUF_1_14
SL_LINKS
SL_RECHTS
AUSLAUF_OHNE_FS
CLOSE_AUSSEN
patch types:
8
wall
wall
wall
wall
wall
wall
wall
wall
point zone names:
0
face zone names:
0
cell zone names:
1
SOLID
wikstrom January 28, 2009 05:28
This problem seems to remain i
This problem seems to remain in version 1.5.x, BUT in my case it probably has to do with the creation of functionObjects. When these are removed from the controlDicts, it works OK.
regards
Niklas
wes1204 November 7, 2014 17:27
thanks
really thank to you
I struggle with same problem for 3 days.
the problem was solved with deleting function in controldict.
