-   OpenFOAM Bugs (http://www.cfd-online.com/Forums/openfoam-bugs/)
-   -   Bugs in fvcsurfaceIntegrate (http://www.cfd-online.com/Forums/openfoam-bugs/62355-bugs-fvcsurfaceintegrate.html)
su_junwei January 5, 2009 09:01
Dear foamers what is t
Dear foamers
what is the difference between fvc::surfaceIntegrate and fvc::surfaceSum?
Isn't it an additional division of volume in fvc::surfaceIntegrate ?
I have just noticed that they are different when suming the surface field
In fvc::surfaceIntegrate, it is
forAll(owner, facei)
ivf[owner[facei]] += issf[facei];
ivf[neighbour[facei]] -= issf[facei];
while in fvc::surfaceSum, it is
ivf[neighbour[facei]] += issf[facei];
Why they are different when dealing with neighbour cell for the current face?
Is it a bug for fvc::surfaceIntegrate?
Junwei
henry January 5, 2009 09:45
"surfaceIntegrate" forms the b
"surfaceIntegrate" forms the basis of the Gauss integrals for evaluating explicit derivatives, see e.g. fvc::div. The reason there is a change of sign is that the face-areas are outward-pointing from the "owner" and hence inward-pointing to the "neighbour". This is assuming what is being "summed" is some kind of flux, i.e. something multiplied or dotted with the cell face areas.
"surfaceSum" is simply that, a sum of a surface field over the cell-faces which is needed for some forms of averaging.
H
nimasam July 29, 2010 11:09
fvc :: reconstruc
hi dear friend
what dose "fvc :: reconstruct" do exactly ?
i have a "surfaceScalarField" and i want to change it to a "volumeScalarField", what can i do ?
can i use fvc :: reconstruct ? whats its effect on data?
Anne Lincke June 25, 2013 13:10
The surfaceIntegrate utility sounds very useful to me.
Is it possible to apply this for a face-based source term inside the UEqn()?
For which objects can we use this method?
When applying this to velocity U I obtain an error message.
Thank you for an answer in advance.
Kind Regards
Anne Lincke
wyldckat July 7, 2013 10:29
Greetings Anne,
It would help if you provided more information about the problem at hand.
I can only guess that the following might help you understand better how OpenFOAM's "reconstruct" and "interpolate" work: https://github.com/wyldckat/reconstr...te-fields/wiki
Best regards,
Bruno
