July 2, 2009, 08:39 |
SVN revision number in OF-1.5-dev
Hannes Kröger
Rep Power: 18 |
in $WM_PROJECT_DIR/bin/foamVersion, the revision number is extracted by this command:
FOAM_DEV_SVN_REVISION_NUMBER=`$SVN_CMD info $WM_PROJECT_DIR | grep "Last Changed Rev:" | awk '{print $4}'`; This only works, if english is selected as system language. With the following modification, the command would be independent from the selected language: FOAM_DEV_SVN_REVISION_NUMBER=`LANG=en $SVN_CMD info $WM_PROJECT_DIR | grep "Last Changed Rev:" | awk '{print $4}'`; Best regards, Hannes |
July 2, 2009, 09:12 |
#2 | |
Martin Beaudoin
Rep Power: 22 |
My bad... I will modify this script so it will not be dependant on the locale settings. Could you show me what is the output of the following command on your workstation: svn info $WM_PROJECT_DIR Thank you for your patience. Martin Quote:
July 2, 2009, 09:21 |
Hannes Kröger
Rep Power: 18 |
Hello Martin,
it gives the following: Pfad: /home/kroegeh/OpenFOAM/OpenFOAM-1.5-dev URL: https://openfoam-extend.svn.sf.net/s...enFOAM-1.5-dev Basis des Projektarchivs: https://openfoam-extend.svn.sf.net/s...penfoam-extend UUID des Projektarchivs: e4e07f05-0c2f-0410-a05a-b8ba57e0c909 Revision: 1316 Knotentyp: Verzeichnis Plan: normal Letzter Autor: hjasak Letzte geänderte Rev: 1315 Letztes Änderungsdatum: 2009-07-01 18:08:34 +0200 (Mi, 01. Jul 2009) Regards, Hannes |
July 2, 2009, 09:26 |
#4 | |
Martin Beaudoin
Rep Power: 22 |
Hello Hannes,
Yep... silly mistake on my part... I will fix this right away. Thanks to you and Jens Klostermann for reporting this. Best regards Martin Quote:
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
