-   OpenFOAM Bugs (http://www.cfd-online.com/Forums/openfoam-bugs/)
-   -   Paraview cannot compile (http://www.cfd-online.com/Forums/openfoam-bugs/62397-paraview-cannot-compile.html)
cvv October 23, 2008 11:58
Hi, I am still getting up t
I am still getting up to speed with OpenFOAM and will appreciate some help.
I have SLED10 on my machine and had to install QT V 4.3.5 as indicated. I get the following output when I run the following commands ( see output below message):
foamInstallationTest
qmake --version
buildParaView3.3-cvs
It looks like I need a library libmpfr.so.1. Where do I get it or is there something else wrong?
Regards
Carel
carel@cfdnb02:~/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin> foamInstallationTest
Executing /home/carel/OpenFOAM/OpenFOAM-1.5/bin/foamInstallationTest:
Checking basic setup...
Shell: bash
Host: cfdnb02
OS: Linux version 2.6.22.5-31-smp
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/carel/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/carel/OpenFOAM/carel-1.5 yes no
$WM_THIRD_PARTY_DIR /home/carel/OpenFOAM/ThirdParty yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/carel/OpenFOAM/OpenFOAM-1.5 yes yes yes
$FOAM_APPBIN ...1.5/applications/bin/linux64GccDPOpt yes yes yes
$FOAM_USER_APPBIN ...1.5/applications/bin/linux64GccDPOpt yes yes no
$WM_DIR /home/carel/OpenFOAM/OpenFOAM-1.5/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...OAM/OpenFOAM-1.5/lib/linux64GccDPOpt yes yes yes
$FOAM_USER_LIBBIN ...enFOAM/carel-1.5/lib/linux64GccDPOpt yes yes no
$MPI_ARCH_PATH ...nmpi-1.2.6/platforms/linux64GccDPOpt yes yes yes
Third party software
Software Version Location
gcc 4.3.1 ...penFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc
gzip 1.3.5 /usr/bin/gzip
tar 1.15.1 /bin/tar
icoFoam 1.5 .../OpenFOAM-1.5/applications/bin/linux64GccDPOpt/icoFoam
Checking networking...
Action Result Crit
Pinging_cfdnb02 Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the OpenFOAM enviroment.
Base configuration ok.
Critical systems ok.
done.
carel@cfdnb02:~/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin> qmake --version
QMake version 2.01a
Using Qt version 4.3.5 in /usr/lib64
carel@cfdnb02:~/OpenFOAM/ThirdParty> buildParaView3.3-cvs
Building ParaView3.3-cvs
MPI support : OFF
Python support : OFF
MESA support : OFF
Source : /home/carel/OpenFOAM/ThirdParty/ParaView3.3-cvs
Target : /home/carel/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc
-- Check for working C compiler: /home/carel/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc
-- Check for working C compiler: /home/carel/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc -- broken
CMake Error: The C compiler "/home/carel/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc" is not able to compile a simple test program.
It fails with the following output:
/usr/bin/gmake -f CMakeFiles/cmTryCompileExec.dir/build.make CMakeFiles/cmTryCompileExec.dir/build
gmake[1]: Entering directory `/home/carel/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/CMakeFiles /CMakeTmp'
/home/carel/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux64/bin/cmake -E cmake_progress_report /home/carel/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/CMakeFiles/ CMakeTmp/CMakeFiles 1
Building C object CMakeFiles/cmTryCompileExec.dir/testCCompiler.o
/home/carel/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc -o CMakeFiles/cmTryCompileExec.dir/testCCompiler.o -c /home/carel/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/CMakeFiles/ CMakeTmp/testCCompiler.c
/home/carel/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../libexec/gcc/x 86_64-unknown-linux-gnu/4.3.1/cc1: error while loading shared libraries: libmpfr.so.1: cannot open shared object file: No such file or directory
gmake[1]: *** [CMakeFiles/cmTryCompileExec.dir/testCCompiler.o] Error 1
gmake[1]: Leaving directory `/home/carel/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/CMakeFiles /CMakeTmp'
gmake: *** [cmTryCompileExec/fast] Error 2
CMake will not be able to correctly generate this project.
-- Configuring done
make: *** No targets specified and no makefile found. Stop.
done
mattijs October 23, 2008 14:43
You might be able to download
You might be able to download it. Alternatively you can download all the sources to the Thirdparty directory and use a script like the following (modify for your situation). Should produce in the end a working gcc.
http://www.cfd-online.com/OpenFOAM_D...hment_icon.gif Allwmake-gcc
