Problem of compilation OF 14Allwmake command not found |
May 10, 2007, 08:52 |
I am new to use Open
I am new to use OpenFOAM and I have some problems to compile it. Description: I downloaded all the packages from the web site (General source, gcc, paraview, double and simple precision, java) I followed all the instruction in the README file (modifications of the bashrc) And when I try to compile the code, all seems to work until I obtain this error message: `/home/linux2/OpenFOAM/OpenFOAM-1.4/lib/linuxGcc4DPOpt/libfoamUtil.so' is up to date. + cd applications + ./Allwmake + cd solvers + wmake all make[1]: Entering directory `/home/linux2/OpenFOAM/OpenFOAM-1.4/applications/solvers/compressible' /home/linux2/OpenFOAM/OpenFOAM-1.4/wmake/wmake: line 162: Allwmake: command not found make[1]: *** [rhopSonicFoam] Error 127 make[1]: Leaving directory `/home/linux2/OpenFOAM/OpenFOAM-1.4/applications/solvers/compressible' make: *** [compressible] Error 2 + cd utilities + wmake all make[1]: Entering directory `/home/linux2/OpenFOAM/OpenFOAM-1.4/applications/utilities/thermophysical' make[2]: Entering directory `/home/linux2/OpenFOAM/OpenFOAM-1.4/applications/utilities/thermophysical/equili briumCO' Making dependency list for source file equilibriumCO.C make[2]: Leaving directory `/home/linux2/OpenFOAM/OpenFOAM-1.4/applications/utilities/thermophysical/equili briumCO' make[2]: Entering directory `/home/linux2/OpenFOAM/OpenFOAM-1.4/applications/utilities/thermophysical/equili briumCO' SOURCE=equilibriumCO.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/linux2/OpenFOAM/OpenFOAM-1.4/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/home/linux2/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGcc4DPOpt/equilibriumCO.o g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/linux2/OpenFOAM/OpenFOAM-1.4/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/home/linux2/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude -fPIC -pthread Make/linuxGcc4DPOpt/equilibriumCO.o -L/home/linux2/OpenFOAM/OpenFOAM-1.4/lib/linuxGcc4DPOpt \ -lspecie -lOpenFOAM -liberty -ldl -lm -o /home/linux2/OpenFOAM/OpenFOAM-1.4/applications/bin/linuxGcc4DPOpt/equilibriumCO /usr/bin/ld: cannot find -lOpenFOAM collect2: ld returned 1 exit status make[2]: *** [/home/linux2/OpenFOAM/OpenFOAM-1.4/applications/bin/linuxGcc4DPOpt/equilibriumC O] Error 1 make[2]: Leaving directory `/home/linux2/OpenFOAM/OpenFOAM-1.4/applications/utilities/thermophysical/equili briumCO' make[1]: *** [equilibriumCO] Error 2 make[1]: Leaving directory `/home/linux2/OpenFOAM/OpenFOAM-1.4/applications/utilities/thermophysical' make: *** [thermophysical] Error 2 + '[' 0 = 1 -a '' = doc ']' Platform: I am working with a RedHat 9 Enterprise and my OS is CentOs 4 Version: I downloaded the OpenFOAM v 1.4 for Linux 32 bits. Notes: I tried several times to compile the code with different protocol and I have still the same problem. It seems that an wmake is lacking inside the compressible folder... To unpack the source code I used tar -xzf <name_file> and do it inside $HOME/OpenFOAM. I created $HOME/OpenFOAM/Linux to put all the binary files. So, if you have any ideas to solve my problem I will be very grateful. (I am very new to use Linux and may be I do something wrong to compile it.) Thanks. Erik. |
May 10, 2007, 08:56 |
Rep Power: 22 |
On line 162 of file /home/linux2/OpenFOAM/OpenFOAM-1.4/wmake/wmake change Allwmake to ./Allwmake |
May 10, 2007, 09:10 |
Thanks for your help. But I st
Thanks for your help. But I still have a problem:
/usr/bin/ld: cannot find -lOpenFOAM collect2: ld returned 1 exit status make[2]: *** [/home/linux2/OpenFOAM/OpenFOAM-1.4/applications/bin/linuxGcc4DPOpt/rhopSonicFoa m] Error 1 Do I have to change something during the configuration? Because it seems strange for me that he need to go in /usr/bin/ld to find a file of OpenFOAM which is unpack in /home/linux2/OpenFOAM. Erik. |
June 26, 2007, 16:28 |
Another Allwmake 'bug' in OF-1
Håkan Nilsson
Rep Power: 18 |
Another Allwmake 'bug' in OF-1.4:
OpenFOAM/OpenFOAM-1.4/applications/utilities/parallelProcessing/Allwmake: Line 4, change to: (cd decompositionMethods; ./Allwmake) Håkan |
June 26, 2007, 16:32 |
In the bug section I posted a
Alberto Passalacqua
Rep Power: 36 |
In the bug section I posted a "cumulative" patch. It will fix that issue too.
Regards, Alberto
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
August 8, 2008, 14:44 |
Hi, I am trying to compile Ope
MR Amiralaei
Rep Power: 17 |
Hi, I am trying to compile OpenFOAM-1.4.1-dev, but I have the same problem, even more.
After ./Allwmake: /usr/bin/ld: cannot find -lOpenFOAM collect2: ld returned 1 exit status make[3]: *** [/home/reza/OpenFOAM/OpenFOAM-1.4.1-dev/applications/bin/linuxGccSPDebug/wallHea tFlux] Error 1 make[2]: *** [wallHeatFlux] Error 2 make[2]: Target `application' not remade because of errors. make[1]: *** [wall] Error 2 make[1]: Target `application' not remade because of errors. make: *** [postProcessing] Error 2 make: Target `application' not remade because of errors. + [ 0 = 1 -a = doc ] After typing wmake libso OpenFOAM: reza@reza-laptop:~/OpenFOAM/OpenFOAM-1.4.1-dev/src$ wmake libso OpenFOAM /usr/bin/ld: cannot find -lfoamUser collect2: ld returned 1 exit status make: *** [/home/reza/OpenFOAM/OpenFOAM-1.4.1-dev/lib/linuxGccSPDebug/libOpenFOAM.so] Error 1 Showing that the library is not there!!! This is the page I follow http://72.14.205.104/search?q=cache:K9Hgdkq7GbYJ:openfoamwiki.net/index.php/Howt o_compile_OpenFOAM+http://openfoamwiki.net/index.php/Ho..._OpenFOAM&hl=e n&gl=us&strip=1 , but when I track the procedure and messages I cannot see any warning or error up to ./Allwmake. I am using ubuntu8.04, 32 bit. I have also installed every thing I saw in the forum: build-essential package, flex++, tcl, tk, xorg. Any idea about what I have to do is appreciated. |
August 8, 2008, 14:55 |
I have to be more specific, I
MR Amiralaei
Rep Power: 17 |
I have to be more specific, I really do not have lopeanfoam library in reza@reza-laptop:~/OpenFOAM/OpenFOAM-1.4.1-dev/lib/linuxGccSPDebug$.
I am really interested in knwoing what mistake I have made |
August 9, 2008, 06:01 |
You have to attach the full output from your compilation attempts. >I am really interested in knwoing what mistake I have made Your mistake is to assume that we have either access to your history and log files or that each of us has a crystal ball on their desks to read all the information that you didn't provide. |
August 10, 2008, 18:18 |
Nadine,
I am not saying tha
#9 |
MR Amiralaei
Rep Power: 17 |
Nadine,
I am not saying that you can read my palm by my post, however your are so right. I just thought that maybe somebody has gone through the HowToCompile wiki and obtained the same result. I am compiling every thing from the very beginning steps and will post all the output, so big, of every step of the compilation. |
August 10, 2008, 18:31 |
Nadine,
Do I have to list the
#10 |
MR Amiralaei
Rep Power: 17 |
Nadine,
Do I have to list the compilation of all the steps, binutils, cmake, ..., or the compilation of OpenFOAM, result of ./Allwmake, is enough. |
August 11, 2008, 13:07 |
Here is my very very basic que
#11 |
MR Amiralaei
Rep Power: 17 |
Here is my very very basic question:
What is the file containing errors, although seems stupid: where is the place I can find the full output, errors, I get during Allwmake, in the log file there is no error reported. P. S. I first saw beautiful linux Ubuntu 8.04 when trying to learn OpenFOAM first P. S. I thought it is the log file containing the full information. |
August 12, 2008, 06:50 |
Which log file do you refer to
#12 |
Which log file do you refer to?
Assuming your shell is set to bash (check with 'echo $SHELL'), the command ./Allwmake > logfile only logs stdout, no error messages. You can do ./Allwmake 1> logfile 2>errfile #or ./Allwmake &> logerrfile to write the error messages into a different or into the same file, respectively. If your shell is some sort of csh, the commands are different. |
August 15, 2008, 12:56 |
Hi all,
I am running OpenSuse
#13 |
Daniel Pinchak
Hi all,
I am running OpenSuse 11. I need to get OpenFOAM-1.4.1-dev and I follow HowTOCompile wiki. However in step 10, compiling openfoam, After ./Allwmake I get: daniel@linux-heys:~/OpenFOAM/OpenFOAM-1.4.1-dev> ./Allwmake + cd wmake + ./makeWmake Makefile:61: /rules//general: No such file or directory Makefile:62: /rules: No such file or directory make: *** No rule to make target `/rules'. Stop. + cd src + ./Allwmake + cd /OpenFOAM ./Allwmake: line 4: cd: /OpenFOAM: No such file or directory + wmakeLnInclude . ./Allwmake: line 4: wmakeLnInclude: command not found + wmake libso zlib-1.2.3 ./Allwmake: line 6: wmake: command not found + '[' '' = OPENMPI -a '!' -r /lib/libmpi.a -a '!' -r /lib/libmpi.so-a '!' -r /lib/libmpi.dylib ']' + '[' '' = LAM -a '!' -r /lib/libmpi.a -a '!' -r /lib/libmpi.so -a '!' -r /lib/libmpi.dylib ']' + '[' '' = MPICH -a '!' -r /lib/libmpich.a -a '!' -r /lib/libmpich.so -a '!' -r /lib/libmpich.dylib ']' + cd Pstream + ./Allwmake + wmake libso dummy ./Allwmake: line 4: wmake: command not found + '[' '' = LAM -o '' = OPENMPI -o '' = MPI -o '' = MPICH -o '' = MPICH-GM -o '' = MPIGAMMA ']' + '[' '' = GAMMA ']' + wmake libso OpenFOAM ./Allwmake: line 112: wmake: command not found + wmake libso lduSolvers ./Allwmake: line 114: wmake: command not found + wmake libso lagrangian/basic ./Allwmake: line 115: wmake: command not found + wmake libso triSurface ./Allwmake: line 117: wmake: command not found + wmake libso edgeMesh ./Allwmake: line 118: wmake: command not found + wmake libso meshTools ./Allwmake: line 119: wmake: command not found + wmake libso finiteVolume ./Allwmake: line 121: wmake: command not found + wmake libso coupledMatrix ./Allwmake: line 122: wmake: command not found + cd MGridGenGamgAgglomeration + ./Allwmake ./Allwmake: line 1: wmake: command not found ./Allwmake: line 2: wmake: command not found ./Allwmake: line 3: wmake: command not found + wmake libso sampling ./Allwmake: line 126: wmake: command not found + wmake libso dynamicMesh ./Allwmake: line 128: wmake: command not found + cd tetDecompositionFiniteElement + ./Allwmake ./Allwmake: line 3: wmake: command not found ./Allwmake: line 4: wmake: command not found + cd tetDecompositionMotionSolver + ./Allwmake ./Allwmake: line 3: wmake: command not found ./Allwmake: line 4: wmake: command not found + wmake libso fvMotionSolver ./Allwmake: line 133: wmake: command not found + wmake libso dynamicFvMesh ./Allwmake: line 134: wmake: command not found + wmake libso topoChangerFvMesh ./Allwmake: line 135: wmake: command not found + wmake libso engine ./Allwmake: line 136: wmake: command not found + wmake libso ODE ./Allwmake: line 138: wmake: command not found + wmake libso randomProcesses ./Allwmake: line 139: wmake: command not found + cd thermophysicalModels + ./Allwmake + wmake libso specie ./Allwmake: line 4: wmake: command not found + wmake libso thermophysicalFunctions ./Allwmake: line 5: wmake: command not found + wmake libso liquids ./Allwmake: line 6: wmake: command not found + wmake libso liquidMixture ./Allwmake: line 7: wmake: command not found + wmake libso basic ./Allwmake: line 9: wmake: command not found + wmake libso combustion ./Allwmake: line 10: wmake: command not found + wmake libso laminarFlameSpeed ./Allwmake: line 11: wmake: command not found + wmake libso chemistryModel ./Allwmake: line 12: wmake: command not found + wmake libso pdfs ./Allwmake: line 13: wmake: command not found + cd transportModels + ./Allwmake + wmake libso incompressible ./Allwmake: line 4: wmake: command not found + wmake libso interfaceProperties ./Allwmake: line 5: wmake: command not found + cd turbulenceModels + ./Allwmake + wmake libso incompressible ./Allwmake: line 4: wmake: command not found + wmake libso compressible ./Allwmake: line 5: wmake: command not found + cd LESmodels + ./Allwmake + wmake libso LESfilters ./Allwmake: line 4: wmake: command not found + wmakeLnInclude incompressible ./Allwmake: line 5: wmakeLnInclude: command not found + wmake libso LESdeltas ./Allwmake: line 6: wmake: command not found + wmake libso incompressible ./Allwmake: line 7: wmake: command not found + wmake libso compressible ./Allwmake: line 8: wmake: command not found + cd postProcessing + ./Allwmake ./Allwmake: line 3: wmake: command not found + cd lagrangian + ./Allwmake + wmake libso basic ./Allwmake: line 4: wmake: command not found + wmake libso dieselSpray ./Allwmake: line 5: wmake: command not found + wmake libso solidParticle ./Allwmake: line 6: wmake: command not found + wmake libso finiteArea ./Allwmake: line 149: wmake: command not found + wmake libso errorEstimation ./Allwmake: line 151: wmake: command not found + wmake libso Gstream ./Allwmake: line 153: wmake: command not found + cd malloc + ./Allwmake + wmake libo fbsdmalloc ./Allwmake: line 4: wmake: command not found + '[' '!' -r /lib/libmico.a ']' + cd + make distclean make: *** No rule to make target `distclean'. Stop. + ./configure --prefix= --disable-shared --without-x ./Allwmake: line 161: ./configure: No such file or directory + make make: *** No targets specified and no makefile found. Stop. + make install make: *** No rule to make target `install'. Stop. + make distclean make: *** No rule to make target `distclean'. Stop. + cd .. + cd applications + ./Allwmake + cd solvers + wmake all ./Allwmake: line 4: wmake: command not found + cd utilities + wmake all ./Allwmake: line 5: wmake: command not found + '[' 0 = 1 -a '' = doc ']' I am new to linux and OpenFOAM. Any idea is appreciated. P. S. I tried to install every missing feature in Suse by DVD becuase a lot of them were missing. |
September 13, 2008, 21:45 |
Hi Daniel,
Not sure if thi
#14 |
Adam Donaldson
Rep Power: 17 |
Hi Daniel,
Not sure if this was resolved for you, as you posted it quite a while ago. This error occured for me when I had an incorrect entry for WM_COMPILER_BIN in the settings.sh file. make sure that it references: WM_COMPILER_BIN=$WM_COMPILER_DIR/bin Hope this helps. |
[OpenFOAM] ParaView command not found | joey | ParaView | 12 | January 18, 2021 05:38 |
Problem FoamXHostBrowser not found after successful compilation | david_flo1 | OpenFOAM | 0 | January 21, 2008 22:04 |
Bash g command not found | mamaly60 | OpenFOAM Installation | 0 | October 18, 2007 17:14 |
Compilation problem crtbegino not found | fred | OpenFOAM Installation | 4 | April 30, 2007 09:36 |
Problem running paraFoam paraview command not found | spdracer22 | OpenFOAM Pre-Processing | 2 | December 7, 2005 05:32 |
