Hi there!
I'm working withi
Hi there!
I'm working within the Federal Waterway Research Institute in Germany and am currently evaluating the possibilities to use OpenFOAM for our tasks. Currently we're using an University-code (NaSt3D) and a commercial code (Comet, CD-Adapco). After successfully compiling OpenFOAM and all of its dependencies on our cluster (HP, ~550 cores, it was a $§%& to do it) I started a series of scaling tests. During these tests I observed, that the serial version of lesInterFoam is more stable than the parallel version. In the appended protocol you can see, that the serial version keeps the timestep length (based on CFL-number) approximately constant, while the parallel version suddenly diverges and thus heavily decreases the timestep length. I tried to tighten the solver tolerances a little (switched from relative to absolute tolerances) and observed that the parallel solver has more difficulties (=needs more iterations) to reach the same residuals. Can anybody help me out? Thanks, Carsten ********************************************* Protocol of serial run: ********************************************* thorenz@manager:/cwork/home/thorenz/OpenFOAM/thorenz-1.5/run/test/lesInter> lesInterFoam /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.5 | | \ / A nd | Web: http://www.OpenFOAM.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : lesInterFoam Date : Sep 11 2008 Time : 15:16:43 Host : manager PID : 3366 Case : /cwork/home/thorenz/OpenFOAM/thorenz-1.5/run/test/lesInter nProcs : 1 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading environmentalProperties Reading field pd Reading field gamma Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Calculating field g.h Selecting LES turbulence model oneEqEddy oneEqEddyCoeffs { ck 0.07; ce 1.05; } time step continuity errors : sum local = 1.90779e-06, global = -5.47287e-11, cumulative = -5.47287e-11 GAMG: Solving for pcorr, Initial residual = 1, Final residual = 0.00933394, No Iterations 2 GAMG: Solving for pcorr, Initial residual = 0.0512361, Final residual = 0.000329517, No Iterations 3 GAMG: Solving for pcorr, Initial residual = 0.0104888, Final residual = 8.43108e-05, No Iterations 3 time step continuity errors : sum local = 3.49924e-10, global = 5.72863e-20, cumulative = -5.47287e-11 Courant Number mean: 0.00198285 max: 0.0870045 Starting time loop Courant Number mean: 0.00911609 max: 0.4 deltaT = 0.00459746 Time = 0.00459746 MULES: Solving for gamma MULES: Solving for gamma Liquid phase volume fraction = 0.634909 Min(gamma) = 0 Max(gamma) = 1 MULES: Solving for gamma MULES: Solving for gamma Liquid phase volume fraction = 0.634909 Min(gamma) = 0 Max(gamma) = 1 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 7.93338e-08, No Iterations 3 GAMG: Solving for pd, Initial residual = 1, Final residual = 0.00320971, No Iterations 2 GAMG: Solving for pd, Initial residual = 0.0167016, Final residual = 9.48718e-05, No Iterations 3 GAMG: Solving for pd, Initial residual = 0.00380673, Final residual = 2.70428e-05, No Iterations 3 GAMG: Solving for pd, Initial residual = 0.00432735, Final residual = 3.22664e-05, No Iterations 3 GAMG: Solving for pd, Initial residual = 0.000806934, Final residual = 4.26216e-06, No Iterations 4 GAMG: Solving for pd, Initial residual = 0.000406143, Final residual = 3.9094e-06, No Iterations 2 GAMG: Solving for pd, Initial residual = 0.000464116, Final residual = 2.95828e-06, No Iterations 3 GAMG: Solving for pd, Initial residual = 0.000104657, Final residual = 8.68852e-07, No Iterations 3 GAMG: Solving for pd, Initial residual = 2.20723e-05, Final residual = 1.40261e-07, No Iterations 4 time step continuity errors : sum local = 7.32954e-12, global = 3.03771e-19, cumulative = -5.47287e-11 ExecutionTime = 246.65 s ClockTime = 247 s Courant Number mean: 0.00911652 max: 0.349656 deltaT = 0.0051234 Time = 0.00972087 MULES: Solving for gamma MULES: Solving for gamma Liquid phase volume fraction = 0.634909 Min(gamma) = 0 Max(gamma) = 1 MULES: Solving for gamma MULES: Solving for gamma Liquid phase volume fraction = 0.634909 Min(gamma) = 0 Max(gamma) = 1 DILUPBiCG: Solving for k, Initial residual = 0.0908774, Final residual = 2.74663e-07, No Iterations 2 GAMG: Solving for pd, Initial residual = 0.091115, Final residual = 0.000455897, No Iterations 3 GAMG: Solving for pd, Initial residual = 0.0105126, Final residual = 5.57734e-05, No Iterations 3 GAMG: Solving for pd, Initial residual = 0.0020783, Final residual = 1.13856e-05, No Iterations 4 GAMG: Solving for pd, Initial residual = 0.00458803, Final residual = 2.51287e-05, No Iterations 3 GAMG: Solving for pd, Initial residual = 0.000711904, Final residual = 7.00776e-06, No Iterations 3 GAMG: Solving for pd, Initial residual = 0.00020928, Final residual = 1.67668e-06, No Iterations 3 GAMG: Solving for pd, Initial residual = 0.000257756, Final residual = 2.29231e-06, No Iterations 3 GAMG: Solving for pd, Initial residual = 5.52424e-05, Final residual = 3.29901e-07, No Iterations 4 GAMG: Solving for pd, Initial residual = 2.64538e-05, Final residual = 2.04274e-07, No Iterations 2 time step continuity errors : sum local = 7.20551e-12, global = 3.81516e-19, cumulative = -5.47287e-11 ExecutionTime = 425.79 s ClockTime = 426 s Courant Number mean: 0.0101599 max: 0.38734 deltaT = 0.00529085 Time = 0.0150117 MULES: Solving for gamma MULES: Solving for gamma Liquid phase volume fraction = 0.634909 Min(gamma) = 0 Max(gamma) = 1 MULES: Solving for gamma MULES: Solving for gamma Liquid phase volume fraction = 0.634909 Min(gamma) = 0 Max(gamma) = 1 DILUPBiCG: Solving for k, Initial residual = 0.0281467, Final residual = 1.8522e-07, No Iterations 2 GAMG: Solving for pd, Initial residual = 0.110235, Final residual = 0.000596557, No Iterations 4 GAMG: Solving for pd, Initial residual = 0.0224509, Final residual = 0.000128465, No Iterations 3 GAMG: Solving for pd, Initial residual = 0.00580166, Final residual = 4.29631e-05, No Iterations 2 GAMG: Solving for pd, Initial residual = 0.00530598, Final residual = 2.74172e-05, No Iterations 4 GAMG: Solving for pd, Initial residual = 0.00113712, Final residual = 6.09731e-06, No Iterations 4 GAMG: Solving for pd, Initial residual = 0.000345295, Final residual = 2.0767e-06, No Iterations 3 GAMG: Solving for pd, Initial residual = 0.000285847, Final residual = 2.27749e-06, No Iterations 3 GAMG: Solving for pd, Initial residual = 6.69878e-05, Final residual = 5.03613e-07, No Iterations 4 GAMG: Solving for pd, Initial residual = 2.31656e-05, Final residual = 1.10384e-07, No Iterations 4 time step continuity errors : sum local = 4.11883e-12, global = 3.21917e-19, cumulative = -5.47287e-11 ExecutionTime = 614.52 s ClockTime = 615 s Courant Number mean: 0.0104904 max: 0.374926 deltaT = 0.00564469 Time = 0.0206564 MULES: Solving for gamma MULES: Solving for gamma Liquid phase volume fraction = 0.634909 Min(gamma) = 0 Max(gamma) = 1 MULES: Solving for gamma MULES: Solving for gamma Liquid phase volume fraction = 0.634909 Min(gamma) = 0 Max(gamma) = 1 DILUPBiCG: Solving for k, Initial residual = 0.0149358, Final residual = 1.07743e-07, No Iterations 2 GAMG: Solving for pd, Initial residual = 0.111377, Final residual = 0.000546566, No Iterations 5 GAMG: Solving for pd, Initial residual = 0.0443143, Final residual = 0.000378587, No Iterations 2 GAMG: Solving for pd, Initial residual = 0.00348986, Final residual = 2.93438e-05, No Iterations 4 GAMG: Solving for pd, Initial residual = 0.00580005, Final residual = 3.25267e-05, No Iterations 3 GAMG: Solving for pd, Initial residual = 0.00090779, Final residual = 5.57326e-06, No Iterations 3 GAMG: Solving for pd, Initial residual = 0.000202187, Final residual = 8.91621e-07, No Iterations 4 GAMG: Solving for pd, Initial residual = 0.000261984, Final residual = 1.46064e-06, No Iterations 4 GAMG: Solving for pd, Initial residual = 8.81133e-05, Final residual = 6.75653e-07, No Iterations 3 GAMG: Solving for pd, Initial residual = 2.19288e-05, Final residual = 1.23339e-07, No Iterations 4 time step continuity errors : sum local = 5.2089e-12, global = -2.91032e-20, cumulative = -5.47287e-11 ExecutionTime = 806.01 s ClockTime = 807 s End ********************************************* Protocol of (small) parallel run: ********************************************* thorenz@manager:/cwork/home/thorenz/OpenFOAM/thorenz-1.5/run/test/lesInter> ShowOutput caesar 8303.manager JOBNAME: lesInter Running on cn113 in directory /cwork/home/thorenz/OpenFOAM/thorenz-1.5/run/test/lesInter /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.5 | | \ / A nd | Web: http://www.OpenFOAM.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : /home/thorenz/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/lesInterFoa m -parallel Date : Sep 11 2008 Time : 15:58:06 Host : cn113 PID : 14560 Case : /cwork/home/thorenz/OpenFOAM/thorenz-1.5/run/test/lesInter nProcs : 4 Slaves : 3 ( cn113.14561 cn113.14562 cn113.14563 ) Pstream initialized with: floatTransfer : 1 nProcsSimpleSum : 0 commsType : nonBlocking // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading environmentalProperties Reading field pd Reading field gamma Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Calculating field g.h Selecting LES turbulence model oneEqEddy oneEqEddyCoeffs { ck 0.07; ce 1.05; } time step continuity errors : sum local = 1.95216e-06, global = -2.19068e-08, cumulative = -2.19068e-08 GAMG: Solving for pcorr, Initial residual = 1, Final residual = 0.00789225, No Iterations 4 GAMG: Solving for pcorr, Initial residual = 0.124184, Final residual = 0.000873301, No Iterations 3 GAMG: Solving for pcorr, Initial residual = 0.00939945, Final residual = 5.94039e-05, No Iterations 5 time step continuity errors : sum local = 2.82378e-10, global = -9.42772e-16, cumulative = -2.19068e-08 Courant Number mean: 0.00197842 max: 0.0866421 Starting time loop Courant Number mean: 0.00913374 max: 0.4 deltaT = 0.00461669 Time = 0.00461669 MULES: Solving for gamma MULES: Solving for gamma Liquid phase volume fraction = 0.634909 Min(gamma) = -1.37317e-09 Max(gamma) = 1 MULES: Solving for gamma MULES: Solving for gamma Liquid phase volume fraction = 0.634909 Min(gamma) = -2.09824e-08 Max(gamma) = 1 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 8.32085e-08, No Iterations 3 GAMG: Solving for pd, Initial residual = 1, Final residual = 0.00905161, No Iterations 2 GAMG: Solving for pd, Initial residual = 0.030631, Final residual = 0.000249962, No Iterations 5 GAMG: Solving for pd, Initial residual = 0.0279553, Final residual = 0.000215157, No Iterations 2 GAMG: Solving for pd, Initial residual = 0.0061856, Final residual = 3.29705e-05, No Iterations 4 GAMG: Solving for pd, Initial residual = 0.0010291, Final residual = 5.35965e-06, No Iterations 4 GAMG: Solving for pd, Initial residual = 0.000249627, Final residual = 2.24523e-06, No Iterations 3 GAMG: Solving for pd, Initial residual = 0.000487803, Final residual = 3.99529e-06, No Iterations 3 GAMG: Solving for pd, Initial residual = 0.000113732, Final residual = 8.44721e-07, No Iterations 4 GAMG: Solving for pd, Initial residual = 2.91779e-05, Final residual = 2.47841e-07, No Iterations 5 time step continuity errors : sum local = 1.42955e-11, global = -2.7288e-13, cumulative = -2.19071e-08 ExecutionTime = 107.67 s ClockTime = 111 s Courant Number mean: 0.00913342 max: 0.350108 deltaT = 0.00514415 Time = 0.00976084 MULES: Solving for gamma MULES: Solving for gamma Liquid phase volume fraction = 0.634909 Min(gamma) = -8.75307e-09 Max(gamma) = 1 MULES: Solving for gamma MULES: Solving for gamma Liquid phase volume fraction = 0.634909 Min(gamma) = -2.95853e-09 Max(gamma) = 1 DILUPBiCG: Solving for k, Initial residual = 0.090851, Final residual = 2.60962e-07, No Iterations 2 GAMG: Solving for pd, Initial residual = 0.103055, Final residual = 0.000658385, No Iterations 7 GAMG: Solving for pd, Initial residual = 0.0534587, Final residual = 0.000471622, No Iterations 2 GAMG: Solving for pd, Initial residual = 0.00457859, Final residual = 3.11229e-05, No Iterations 6 GAMG: Solving for pd, Initial residual = 0.00674019, Final residual = 4.25671e-05, No Iterations 3 GAMG: Solving for pd, Initial residual = 0.000957393, Final residual = 6.8116e-06, No Iterations 4 GAMG: Solving for pd, Initial residual = 0.000305495, Final residual = 2.13162e-06, No Iterations 4 GAMG: Solving for pd, Initial residual = 0.000338653, Final residual = 2.22752e-06, No Iterations 4 GAMG: Solving for pd, Initial residual = 9.83227e-05, Final residual = 8.53568e-07, No Iterations 4 GAMG: Solving for pd, Initial residual = 1.96595e-05, Final residual = 1.80463e-07, No Iterations 6 time step continuity errors : sum local = 7.49885e-12, global = -6.0042e-13, cumulative = -2.19077e-08 ExecutionTime = 195.31 s ClockTime = 199 s Courant Number mean: 0.0101748 max: 0.387677 deltaT = 0.00530766 Time = 0.0150685 MULES: Solving for gamma MULES: Solving for gamma Liquid phase volume fraction = 0.634909 Min(gamma) = -1.13155e-08 Max(gamma) = 1 MULES: Solving for gamma MULES: Solving for gamma Liquid phase volume fraction = 0.634909 Min(gamma) = -3.14748e-09 Max(gamma) = 1 DILUPBiCG: Solving for k, Initial residual = 0.0280745, Final residual = 2.50708e-07, No Iterations 2 GAMG: Solving for pd, Initial residual = 0.135927, Final residual = 0.0008367, No Iterations 6 GAMG: Solving for pd, Initial residual = 0.12072, Final residual = 0.000949937, No Iterations 2 GAMG: Solving for pd, Initial residual = 0.0067283, Final residual = 6.02786e-05, No Iterations 6 GAMG: Solving for pd, Initial residual = 0.0110492, Final residual = 9.74167e-05, No Iterations 3 GAMG: Solving for pd, Initial residual = 0.00167134, Final residual = 1.60604e-05, No Iterations 5 GAMG: Solving for pd, Initial residual = 0.000762118, Final residual = 5.91042e-06, No Iterations 4 GAMG: Solving for pd, Initial residual = 0.000432036, Final residual = 3.90235e-06, No Iterations 4 GAMG: Solving for pd, Initial residual = 0.0001005, Final residual = 9.58262e-07, No Iterations 5 GAMG: Solving for pd, Initial residual = 3.66069e-05, Final residual = 3.42478e-07, No Iterations 13 time step continuity errors : sum local = 1.73401e-11, global = -1.14339e-12, cumulative = -2.19088e-08 ExecutionTime = 291.55 s ClockTime = 296 s Courant Number mean: 0.010502 max: 2.84169 deltaT = 0.000747113 Time = 0.0158156 MULES: Solving for gamma MULES: Solving for gamma Liquid phase volume fraction = 0.634909 Min(gamma) = -4.97554e-09 Max(gamma) = 1 MULES: Solving for gamma MULES: Solving for gamma Liquid phase volume fraction = 0.634909 Min(gamma) = -2.17027e-08 Max(gamma) = 1 DILUPBiCG: Solving for k, Initial residual = 0.00198818, Final residual = 3.3322e-07, No Iterations 1 GAMG: Solving for pd, Initial residual = 0.279262, Final residual = 0.00205902, No Iterations 5 GAMG: Solving for pd, Initial residual = 0.25002, Final residual = 0.00172857, No Iterations 2 GAMG: Solving for pd, Initial residual = 0.017356, Final residual = 0.000112756, No Iterations 6 GAMG: Solving for pd, Initial residual = 0.0192683, Final residual = 0.00017176, No Iterations 3 GAMG: Solving for pd, Initial residual = 0.00822677, Final residual = 6.5594e-05, No Iterations 3 GAMG: Solving for pd, Initial residual = 0.00343701, Final residual = 2.67641e-05, No Iterations 4 GAMG: Solving for pd, Initial residual = 0.00187906, Final residual = 1.08599e-05, No Iterations 5 GAMG: Solving for pd, Initial residual = 0.00078521, Final residual = 7.42016e-06, No Iterations 3 GAMG: Solving for pd, Initial residual = 0.000177669, Final residual = 1.20193e-06, No Iterations 9 time step continuity errors : sum local = 2.14555e-12, global = -1.17363e-13, cumulative = -2.19089e-08 ExecutionTime = 378.51 s ClockTime = 383 s Courant Number mean: 0.00147797 max: 0.109817 deltaT = 0.000896536 Time = 0.0167122 [snipped] |
Solver convergence behaviour i
Solver convergence behaviour is indeed affected by running in parallel because the effectiveness of the preconditioning and smoothing operations is reduced in the cells adjacent to the processor boundaries which usually causes a modest increase in the number of iterations. But it doesn't look like this is the root of your problems, take a look at the solution and find out where in the domain the Courant number has jumped.
H |
P.S. your pdFinal tolerance ap
P.S. your pdFinal tolerance appears to vary, are you running with a relative tolerance on pdFinal? It should be relTol = 0. Also for efficiency you may benefit from running with fewer correctors and use the GAMG preconditioned CG solver for pdFinal; take a look at the lesInterFoam tutorial.
H |
Hi Henry,
thanks for your e
Hi Henry,
thanks for your explanation about the effectiveness of preconditioning in parallel (didn't know that). Relative tolerance: Yes. But the main problem is not influenced by this. When I switched to constant tolerances, the general behaviour stays the same. (i.e. more iterations in parallel than in serial runs, sudden jumps of the velocity). I will try to find out were it occurs. Many thanks, Carsten |
You seem to be currently runni
You seem to be currently running with floatTransfer (i.e. all doubles get converted to floats just before transfer). This will loose precision which might affect the solver.
@Mattijs:
Thanks for your c
@Mattijs:
Thanks for your comment. That might result in severe truncation errors. I will try it. @Henry: Switching the PD-solver to AMG-preconditioned PCG increased reliability significantly. Thanks a lot. Now I can start some scaling tests on our machine. http://www.cfd-online.com/OpenFOAM_D...part/happy.gif Allow me one more question (though in the wrong forum): Did I understand it correctly, that the pressure p is replaced by pd+rho*g*h? As I understand it, this removes the hydrostatic pressure from the solution and thus results in "less work" for the solver. But this will only be successful, if the waterlevel is located at z=0, otherwise it will be (strongly) contraproductiv? Wouldn't it be more useful to remove the pressure field of the last timestep from the solution and thus express p_new=p_old+pd (with pd=p_new-p_old) and relax updating of p_old? Bye, Carsten |
Yes pd is solved for rather th
Yes pd is solved for rather than p but this is not an approximation, it is a reformulation, note the corresponding change to the buoyancy term. This reformulation allows the buoyancy term to be handled in the pd equation in a much better way in the collocated grid arrangement we use.
H |
I agree that it is just a refo
I agree that it is just a reformulation. But I'm not sure if is useful _in_general_. I.e. in my oppinion it only has a positive effect, if the watertable nearly horizontal?
Just a comment, not an offense http://www.cfd-online.com/OpenFOAM_D...part/happy.gif Carsten |
@Mattijs:
I tried to set fl
@Mattijs:
I tried to set floatTransfer to 0 in my controlDict, but it is not recognized. Where should I set it? Is it hardcoded? Thanks, Carsten |
It is a necessary reformulatio
It is a necessary reformulation for numerical reasons and does not introduce any error or restriction.
H |
floatTransfer: I found that it
floatTransfer: I found that it must be changed in the _global_ controlDict.
Finally, I think the behaviour is a bug. Well, let's say an over-optimization http://www.cfd-online.com/OpenFOAM_D...part/happy.gif floatTransfer should default to 0. It is not reasonable, to decrease the accuracy during mpi-transmission for double-precision compilations. Why should I use double-precision at all if I loose the precision again? About performance: On our machine, the code runs faster with floatTransfer set to 0. The stability is much better (forget all of the above about solver settings) and it needs less iterations to converge. The overhead for the mpi-transmissions is negligible. So, please change the floatTransfer default value to 0 (again). Bye, Carsten |
floatTransfer is not a bug but
floatTransfer is not a bug but a carefully formulated method to get the most accuracy from least comms overhead and has proved very effective when running on cluster machines with Gbit networking for with the overhead of the MPI transmissions is significant. However it is not always appropriate as you have found and I agree that it should not be the default and I will change it in our git repository.
Thanks for sending details of your experience with floatTransfer. H |
| All times are GMT -4. The time now is 02:12. |
