I ran channelOoodles in OF-1.5
I ran channelOoodles in OF-1.5 and have results. However, when I view the results in paraview i receive the following error at each timestep containing written data. Thoughts? How can I change writeGradP.H to include a foamFile header?
--> FOAM Serious Error : From function IOobject::readHeader(Istream&) in file db/IOobject/IOobjectReadHeader.C at line 93 Reading "/home/dcombest/OpenFOAM/dcombest-1.5/run/tutorials/channelOodles/channel395/2.6 /gradP.raw" at line 1 First token could not be read or is not the keyword 'FoamFile' Check header is of the form: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.5 | | \ / A nd | Web: http://www.OpenFOAM.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class IOobject; location "2.6"; object gradP.raw; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // |
Thanks for the problem report.
Thanks for the problem report. I will change the code to write the gradP.raw file into the "uniform" sub-directory where it should really be and upload the change to our git repository.
H |
I have a similar problem:
Thank you. Best regard MT |
