Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Modification of collapseEdges utility
Old   September 9, 2008, 08:35
Default Hi, Among other things, the
Ola Widlund
olwi is on a distinguished road
Among other things, the collapseEdges utility removes faces with area < areaFactor * maxFaceArea, where maxFaceArea is the area of the largest face of the model, and areaFactor is hard-coded to 1e-9.
I happen to run cases where there is a very large difference in size between smallest and largest cells. When working with 2D wedge geometries, I need collapseEdges to clean up after Bernhard's excellent makeAxialMesh utility. In some cases the hard-coded value for areaFactor is to large, and thousands of perfectly healthy faces are marked for removal...
I here humbly contribute a modified version, collapseEdgesBetter, in which the option -areaFactor can be used to set a sound value. If missing, the hard-coded value 1e-9 is used as default.
Best regards,
Ola
collapseEdgesBetter.ZIP
olwi is offline   Reply With Quote
[mesh manipulation] CollapseEdges after makeAxialMesh utility in subversion testcase bonzodeb OpenFOAM Meshing & Mesh Conversion 1 June 5, 2009 03:24
modification of UDF ammi FLUENT 2 January 18, 2007 21:35
KIVA Modification Gede Main CFD Forum 0 May 10, 2006 22:06
modification for CFX? caty CFX 5 May 19, 2005 18:48
UDF modification merac FLUENT 4 March 1, 2001 06:42
