-   OpenFOAM Bugs (http://www.cfd-online.com/Forums/openfoam-bugs/)
-   -   LESProperties and PrandtlDeltaC (http://www.cfd-online.com/Forums/openfoam-bugs/62428-lesproperties-prandtldeltac.html)
wikstrom September 2, 2008 02:45
Dear Developers, Just encou
Dear Developers,
Just encountered a minor inconsistency:
In LESProperties, conveniently all constants are represented by scalars, however PrandtlDelta performs dimensionedScalar lookups.
OpenFOAM version
1.5.x (Pulled from git repo)
Affected files
$FOAM_SRC/turbulenceModels/LES/LESdeltas/PrandtlDelta/PrandtlDelta.C
Simple Fix:
65c65
< kappa_(dimensionedScalar(dd.lookup("kappa")).value ()),
> kappa_(readScalar(dd.lookup("kappa"))),
68,69c68
< dimensionedScalar(dd.subDict(type() + "Coeffs").lookup("Cdelta"))
< .value()
> readScalar(dd.subDict(type() + "Coeffs").lookup("Cdelta"))
83,84c82,83
< kappa_ = dimensionedScalar(d.lookup("kappa")).value();
< Cdelta_ = dimensionedScalar(dd.lookup("Cdelta")).value();
> kappa_ = readScalar(d.lookup("kappa"));
> Cdelta_ = readScalar(dd.lookup("Cdelta"));
Cheers
Niklas
henry September 2, 2008 05:19
Thanks for the bug-report, the
Thanks for the bug-report, the fix is now in the 1.5.x git repository.
H
Sylvain August 9, 2010 08:59
It looks like the proposal of Niklas is not present in 1.7.x version as it still looking for dimensionedScalar Lookups.
When I run pisoFoam it is not finding the kappa constant even if I put it in the dictionary, I don't know yet if it is linked. I will try to recompile the code with Niklas proposal. I'm not sure, I'm a bit lost among all those models and C code...
Sincerely
Sylvain
heather August 9, 2010 09:52
Thanks - I've re-added the code to 1.7.x - should be there the next time you 'git pull'
Andy
