Home > Forums > OpenFOAM Bugs
SolidEqulibriumDisplacementFoam
Old   August 6, 2008, 11:50
Default Description: I tried to dis
karen
Description:
I tried to discretize the beam-domain of the beamEndLoad-tutorial in 3D instead of blocks (about the blockMesh-utility) with tetraeders (about tetgen) and the solidEquilibriumDisplacementFoam-Solver doesn't work anymore.
Details:
I took the beamEndLoad-tutorial, write the mesh of the beam as 3 dimensional and refine it:
convertToMeters 1;
vertices
(0 0 0)
(30 0 0)
(30 1 0)
(0 1 0)
(0 0 1)
(30 0 1)
(30 1 1)
(0 1 1)
blocks
hex (0 1 2 3 4 5 6 7) (60 2 2) simpleGrading (1.0 1.0 1.0)
edges
patches
patch
topSurface
(3 7 6 2)
patch
bottomSurface
(4 0 1 5)
patch
fixedEnd
(0 4 7 3)
patch
tractionEnd
(1 2 6 5)
patch
defaultFaces
(0 3 2 1)
(5 6 7 4)
(Also I switch the planeStress-option in the mechanicalProperties-file)
If I applicate the solidEquilibriumDisplacementFoam I get a solution.
Now I take the same shape of the beam, but create a mesh with tetgen. For that I generate a tetgen-mesh with
tetgen -qfa0.125 beam.poly
where beam.poly is the following file:
# Part 1 - node list
# node count, 3 dim, no attribute, no boundary marker
8 3 0 0
# Node index, node coordinates
1 0.0 0.0 0.0
2 30 0.0 0.0
3 30 1.0 0.0
4 0.0 1.0 0.0
5 0.0 0.0 1.0
6 30 0.0 1.0
7 30 1.0 1.0
8 0.0 1.0 1.0
# Part 2 - facet list
# facet count, boundary marker
6 1
# facets
1 0 1 # 1 polygon, no hole, boundary marker
4 1 2 3 4 # front
1 0 1
4 5 6 7 8 # back
1 0 2
4 1 2 6 5 # bottom
1 0 3
4 2 3 7 6 # right
1 0 4
4 3 4 8 7 # top
1 0 5
4 4 1 5 8 # left
# Part 3 - hole list
0 # no hole
# Part 4 - region list
0 # no region
The obtained mesh (beam.1.node, beam.1.ele, beam.1.face) I converted with tetgenToFoam and applicate the SolidEquilibriumDisplacementFoam-Solver.
Now I get a floating point exception.
So I think I did nothing else than discretize the mesh instead of blocks with tetraeders (about tetgen) and the solidEquilibriumDisplacementFoam-solver didn't work anymore.
Is this a bug?
Application: solidEquilibriumDisplacementFoam
Source: $FOAM_SOLVERS/stressAnalysis/solidEquilibriumDisplacementFoam
Platform: Linux, Version 2.6.18, i686 GNU/Linux
Version: OpenFOAM 1.5
Old   August 7, 2008, 02:38
Default I think I get the floating poi
karen
I think I get the floating point exception, because the solution diverged on the tetgen-mesh.
Thread Tools
Trackbacks are On
