Description:
When planar STL
Description:
When planar STL surfaces which are aligned with coordinate planes are supplied to snappyHexMesh, an error message like to following occurs: ============================================== Edge intersection testing: Number of edges : 74800 Number of edges to retest : 74800 Badly formed bounding boxhttp://www.cfd-online.com/OpenFOAM_D...lipart/sad.gif-0.0720968 0.027 -0.0410269) (0.080055 0.027 0.0410628)#0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) in "/home/cluster/josef/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/cluster/josef/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::indexedOctree<foam::treedatatrisurface>::div ide(Foam::treeBoundBox const&, Foam::DynamicList<foam::list<int>, 0u, 2u, 1u>&, int) const in "/home/cluster/josef/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libmeshTools.so" #3 Foam::indexedOctree<foam::treedatatrisurface>::ind exedOctree(Foam::treeDataTriSu rface const&, Foam::treeBoundBox const&, int, double, double) in "/home/cluster/josef/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libmeshTools.so" #4 Foam::triSurfaceMesh::tree() const in "/home/cluster/josef/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libmeshTools.so" #5 Foam::triSurfaceMesh::findLineAny(Foam::Field<foam ::vector<double> > const&, Foam::Field<foam::vector<double> > const&, Foam::List<foam::pointindexhit<foam::vector<double > > >&) const in "/home/cluster/josef/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libmeshTools.so" #6 Foam::refinementSurfaces::findHigherIntersection(F oam::Field<foam::vector<double > > const&, Foam::Field<foam::vector<double> > const&, Foam::List<int> const&, Foam::List<int>&, Foam::List<int>&) const in "/home/cluster/josef/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libautoMesh.so" #7 Foam::meshRefinement::updateIntersections(Foam::Li st<int> const&) in "/home/cluster/josef/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libautoMesh.so" #8 Foam::meshRefinement::meshRefinement(Foam::fvMesh& , double, Foam::refinementSurfaces const&, Foam::shellSurfaces const&) in "/home/cluster/josef/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libautoMesh.so" #9 main in "/home/cluster/josef/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/snap pyHexMesh" #10 __libc_start_main in "/lib64/libc.so.6" #11 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/cluster/josef/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/snap pyHexMesh" From function indexedOctree<type>::divide in file lnInclude/indexedOctree.C at line 213. FOAM aborting ============================================== The statement after line 205 in $FOAM_SRC/meshTools/lnInclude/indexedOctree.C causes the error: if ( bb.min()[0] >= bb.max()[0] || bb.min()[1] >= bb.max()[1] || bb.min()[2] >= bb.max()[2] ) { FatalErrorIn("indexedOctree<type>::divide") << "Badly formed bounding box:" << bb << abort(FatalError); } If this check is removed and libmeshTools recompiled, the code runs fine without errors. Solver/Application: snappyHexMesh Source file: $FOAM_SRC/meshTools/lnInclude/indexedOctree.C Platform: Linux x86_64, Fedora 9 Version: 1.5 |
Thanks for report. The indexed
Thanks for report. The indexedOctree is for 3D geometry - am surprised it actually produces something useful for 2D geometry. You might get problems with truncation error. Is it possible to get the surface, blockMeshDict and snappyHexMeshDict? (m dot janssens)
