ParaFoam canbt handle cyclic boundaries in channelOodles |
July 17, 2008, 02:21 |
Description:
The error messa
Daniel WEI (老魏)
Rep Power: 21 |
Description:
The error message I met is, # Error or warning: There was a VTK Error in file: /home/dm2/henry/OpenFOAM/linuxSrc/paraview-2.4.4/VTK/Filtering/vtkDataSet.cxx (383) vtkUnstructuredGrid (0x2f06930): Point array volPointInterpolate(nuTilda) with 1 components, only has 1330 tuples but there are 1406 points If I do not select side1, side2, inout1, inout2 in paravew, (all of these four sides are cyclic boundary), then everything goes fine. Solver/Application: paraFoam Source file: ----------- Testcase: channelOodles/channel395 Platform: OpenSUSE-11.0 Version: OpenFOAM-1.5 Notes: no
~ Daniel WEI ------------- Boeing Research & Technology - China Beijing, China |
July 17, 2008, 12:58 |
Thanks. Was interpolation acro
Mattijs Janssens
Rep Power: 26 |
Thanks. Was interpolation across patches which was giving problems - now just set it up to do patch-wise interpolation. The fix is non-trivial so we'll put it out in the next patch (unless it is showstopper)
cyclic boundaries | Zealouk | Siemens | 0 | September 17, 2008 11:28 |
[OpenFOAM] View cyclic boundaries using MRFSimpleFoam | gabriel | ParaView | 0 | July 27, 2007 08:42 |
cyclic boundaries | gosia stein | Siemens | 5 | June 13, 2007 07:39 |
[Gmsh] Cyclic boundaries | sampaio | OpenFOAM Meshing & Mesh Conversion | 1 | February 7, 2006 13:26 |
CYCLIC BOUNDARIES MATCHING | robert | Siemens | 3 | September 7, 2000 01:08 |
