I have copied the .msh file co
I have copied the .msh file converted from adventure on windows to the folder smartvalve in simplefoam
The smartvalve is a new case I created by right clicking on the case browser and by using create case command. The mesh file is placed in the smartvalve case folder. I have not did any proceedings in system and constant directories. First I started the mshToFoam command directly. The mshToFoam command exits as like this *---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4.1 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : mshToFoam OpenFOAM/harikr-1.4.1/run/tutorials/simpleFoam smartvalve CFD Date : Jul 04 2008 Time : 18:21:20 Host : D6 PID : 22462 Root : OpenFOAM/harikr-1.4.1/run/tutorials/simpleFoam Case : smartvalve Nprocs : 1 Create time --> FOAM FATAL IO ERROR : Attempt to get back from bad stream file: CFD at line 1. From function void Istream::getBack(token& t) in file db/IOstreams/IOstreams/Istream.C at line 44. FOAM exiting Could advice me where I had make mistake? |
