During running of blockMesh on
During running of blockMesh on this file
http://www.cfd-online.com/OpenFOAM_D...hment_icon.gif blockMeshDict it could not read a list of points, defining a surface of patch correctly (doesn't see present '('), and writes : ben@r117-1:~/OpenFOAM/ben-1.4.1/run/tutorials/rhoTurbFoam$ blockMesh . mars-b /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4.1 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : blockMesh . mars-b Date : May 19 2008 Time : 07:37:02 Host : r117-1 PID : 3636 Root : /home/ben/OpenFOAM/ben-1.4.1/run/tutorials/rhoTurbFoam Case : mars-b Nprocs : 1 Create time Reading block mesh description dictionary Creating block mesh Creating blockCorners Creating curved edges Creating blocks Creating patches --> FOAM FATAL IO ERROR : Expected a '(' or a '{' while reading List, found on line 113 the label 18 file: /home/ben/OpenFOAM/ben-1.4.1/run/tutorials/rhoTurbFoam/mars-b/constant/polyMesh/blockMeshDict::patches at line 113. From function Istream::readBeginList(const char*) in file db/IOstreams/IOstreams/Istream.C at line 138. FOAM exiting |
If I create default boundary f
If I create default boundary faces by commenting out the patches contents (so just have "patches();")
I get: --> FOAM Warning : ... zero or negative pyramid volume: -7.4816e-06 for face 1 and an error: Creating merge list --> FOAM FATAL ERROR : Inconsistent number of faces between block pair 1 and 10#0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) in "/home/hunt2/mattijs/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::exit(int) in "/home/hunt2/mattijs/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::blockMesh::createMergeList() in "/home/hunt2/mattijs/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/bl ockMesh" #3 Foam::blockMesh::blockMesh(Foam::IOdictionary&) in "/home/hunt2/mattijs/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/bl ockMesh" #4 main in "/home/hunt2/mattijs/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/bl ockMesh" #5 __libc_start_main in "/lib64/libc.so.6" #6 Foam::regIOobject::readIfModified() in "/home/hunt2/mattijs/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/bl ockMesh" From function blockMesh::createMergeList() in file createMergeList.C at line 201. I guess that is what is causing your problem. |
Thank you !
ruben
Thank you !
ruben |
Nevertheless, after solving pr
Nevertheless, after solving problem of zero-sized volume cells, problem of patch reading has repeated
http://www.cfd-online.com/OpenFOAM_D...hment_icon.gif blockMeshDict ruben |
I get no problem Had to add a
I get no problem Had to add a valid header (use FoamX or look at one of the tutorials)
http://www.cfd-online.com/OpenFOAM_D...hment_icon.gif blockMeshDict |
Thank you again, it seems to b
Thank you again, it seems to be OK.
ruben |
hi everyone. i was trying to c
hi everyone. i was trying to create a mesh around a solid cylinder.
can anyone suggest me which will be the best way? as im new to openfoam, i started with quarter part of the whole mesh to be generated containg the quarter of the cylinder. i did it in blockmesh...while executing it, i was finding the following errors. can anyone suggest me what might be the bug in here? /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4.1 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : blockMesh /home/nikhil/OpenFOAM/nikhil-1.4.1/run/tutorials/icoFoam cavi tyGrade Date : Jun 24 2008 Time : 09:42:12 Host : localhost PID : 22816 Root : /home/nikhil/OpenFOAM/nikhil-1.4.1/run/tutorials/icoFoam Case : cavityGrade Nprocs : 1 Create time Reading block mesh description dictionary Creating block mesh Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology Default patch type set to empty Check block mesh topology Basic statistics Number of internal faces : 0 Number of boundary faces : 12 Number of defined boundary faces : 12 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating points Creating cells Creating patches Creating mesh from block mesh Default patch type set to empty Creating merge patch pairs Adding point and face zones Creating attachPolyTopoChanger #0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) in "/home/nikhil/OpenFOAM/OpenFOAM-1 .4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/nikhil/OpenFOAM/OpenFOAM-1.4.1/li b/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xffffe420] #3 Foam::triangle, Foam::Vector const&>::ray(Foam: :Vector const&, Foam::Vector const&, Foam::intersection::algorit hm, Foam::intersection::direction) const in "/home/nikhil/OpenFOAM/OpenFOAM-1.4. 1/lib/linuxGccDPOpt/libmeshTools.so" #4 Foam::face::ray(Foam::Vector const&, Foam::Vector const&, Fo am::Field > const&, Foam::intersection::algorithm, Foam::in tersection::direction) const in "/home/nikhil/OpenFOAM/OpenFOAM-1.4.1/lib/linuxG ccDPOpt/libOpenFOAM.so" #5 Foam::List Foam::PrimitivePatch > const&>::projectPoints > const&> >(Foam::Primitive Patch > const&> const&, Foam::Field > const&, Foam::intersection::algorithm, Foam: :intersection::direction) const in "/home/nikhil/OpenFOAM/OpenFOAM-1.4.1/lib/lin uxGccDPOpt/libdynamicMesh.so" #6 Foam::slidingInterface::projectPoints() const in "/home/nikhil/OpenFOAM/Open FOAM-1.4.1/lib/linuxGccDPOpt/libdynamicMesh.so" #7 Foam::slidingInterface::changeTopology() const in "/home/nikhil/OpenFOAM/Ope nFOAM-1.4.1/lib/linuxGccDPOpt/libdynamicMesh.so" #8 Foam::polyTopoChanger::changeTopology() const in "/home/nikhil/OpenFOAM/Open FOAM-1.4.1/lib/linuxGccDPOpt/libdynamicMesh.so" #9 Foam::polyTopoChanger::changeMesh(bool, bool) in "/home/nikhil/OpenFOAM/Open FOAM-1.4.1/lib/linuxGccDPOpt/libdynamicMesh.so" #10 Foam::attachPolyTopoChanger::attach(bool) in "/home/nikhil/OpenFOAM/OpenFOA M-1.4.1/lib/linuxGccDPOpt/libdynamicMesh.so" #11 main in "/home/nikhil/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOp t/blockMesh" #12 __libc_start_main in "/lib/i686/libc.so.6" #13 Foam::regIOobject::readIfModified() in "/home/nikhil/OpenFOAM/OpenFOAM-1.4. 1/applications/bin/linuxGccDPOpt/blockMesh" regards, nikhil. |
Can anyone find the error of my blockMeshdict?
Dear Foam Community,
I have looked this over but cannot seem to find the problem, wonder if someone else can say what I am doing wrong. Lori:confused: // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Reading block mesh description dictionary Creating block mesh Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology Default patch type set to empty Check block mesh topology Basic statistics Number of internal faces : 13 Number of boundary faces : 34 Number of defined boundary faces : 34 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list Inconsistent number of faces between block pair 3 and 4 From function blockMesh::createMergeList() in file createMergeList.C at line 201. FOAM exiting ---------------------------------BlockMeshDict File---------------------------------------------- /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.4.1 | | \\ / A nd | Web: http://www.openfoam.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.0032; vertices ( (0 0 0) //0 (80 0 0) //1*** (0 1 0) //2 (80 1 0) //3*** (0 2.5 0)//4 (80 2.5 0)//5 (0 4 0) //6 (80 4 0) //7 (130 0 3.75)//8 (130 1 3.75) //9 (0 0 10) //10 (80 0 10)//11 (0 1 10) //12 (80 1 10)//13 (0 2.5 10)//14 (80 2.5 10)//15 (0 4 10) //16 (80 4 10) //17 (130 0 6.25) //18 (130 1 6.25) //19 (80 0 6.25) //20 (80 1 6.25) //21 (80 2.5 6.25)//22 (0 0 6.25) //23 (0 1 6.25) //24 (0 2.5 6.25) //25 (0 4 6.25) //26 (80 4 6.25) //27 //*** indent front face 09/20/09 (80 0 3.75) //28 (80 1 3.75) //29 (0 1 3.75) //30 (0 0 3.75) //31 (0 2.5 3.75) //32 (0 4 3.75) //33 (80 4 3.75) //34 (80 2.5 3.75) //35 ); blocks ( hex (23 20 21 24 10 11 13 12) (150 30 30) simpleGrading (0.002 0.3 1) hex (31 28 29 30 23 20 21 24) (150 30 30) simpleGrading (0.002 0.3 1) hex (0 1 3 2 31 28 29 30) (150 30 30) simpleGrading (0.002 0.3 1) hex (2 3 5 4 30 29 35 32) (150 45 30) simpleGrading (0.002 3.333 1) hex (30 29 35 32 24 21 22 25) (150 30 30) simpleGrading (0.002 0.3 1) hex (24 21 22 25 12 13 15 14) (150 45 30) simpleGrading (0.002 3.333 1) hex (4 5 7 6 32 35 34 33) (150 45 30) simpleGrading (0.002 0.3 1) hex (32 35 34 33 25 22 27 26) (150 45 30) simpleGrading (0.002 0.3 1) hex (25 22 27 26 14 15 17 16) (150 45 30) simpleGrading (0.002 0.3 1) hex (28 8 9 29 20 18 19 21) (90 30 30) simpleGrading (500 0.3 1) ); edges ( ); patches ( patch inlet ( (0 2 30 31) //0 (31 30 24 23) (23 24 12 10) //2 (2 4 32 30) (30 32 25 24) //4 (24 25 14 12) (4 6 33 32) //6 (32 33 26 25) (25 26 16 14) //8 ) wall fixedWalls ( (6 33 34 7) //top of wall R upstream (33 26 27 34) //top of wall M upstream (26 16 17 27) //top of wall L upstream (1 3 29 28) //contract R btm wall (3 5 35 29) //contract R mid wall (5 7 34 35) //contract R top wall (29 35 22 21) //contract M mid wall (35 34 27 22) //contract M top wall (20 21 13 11) //contract L btm wall (21 22 15 13) //contract L mid wall (22 27 17 15) //contract L top wall (29 21 19 9) //top of wall downstream ) patch outlet ( (8 9 19 18) //9 ) symmetryPlane simetry ( (0 1 28 31) //btm sym R upstream (31 28 20 23) //btm sym M upstream (23 20 11 10) //btm sym L upstream (28 8 18 20) //btm sym downstream -direction? ) wall frontAndBack ( (0 2 3 1) //btm frontface upstream (2 4 5 3) //mid frontface upstream (4 6 7 5) //top frontface upstream (28 29 9 8) //btm frontface downstream (10 12 13 11) //btm backface upstream (12 14 15 13) //mid backface upstream (14 16 17 15) //top backface upstream (20 21 19 18) //btm backface upstream ) ); mergePatchPairs ( ); // ************************************************** *********************** // |
No Idea. Did the blockmesh work without the grading? Always go from the simplest (mesh without grading - make sure that that works) to the more complicated. It seems that the meshes on the blocks are not perfectly aligned on the joint face (which the should be). Either because the counts are different (are you sure that all the 45 and 30 are in the right places) or the gradings are different Bernhard |
Dear Bernhard,
Thankyou, I never considered this was the problem and kept checking faces and points. I am always learning but it is working and I will relook at my grading definitions. Also, I know it is not a bug in OF, sorry, I was just replying to an earlier post. Again, Thankyou! Lori Holmes |
1 Attachment(s)
Hi all,
I may have found a bug in blockMesh, but since I'm pretty new at this, I thought I would see if anyone else can confirm that this is a real problem, or just a mistake on my part. The error message I get is... Inconsistent point locations between block pair 0 and 1 probably due to inconsistent grading. From function blockMesh::createMergeList() in file createMergeList.C at line 274. I've attached the blockMeshDict. This is a case that bonzodeb posted about a year and a half ago in this thread. It errored out when I tried it yesterday, so I cleaned it up to try to simplify it and locate the error. The first thing I tried was remove the grading, so you will see the original lines commented out and replaced with blocks that end in simpleGrading (1 1 1) I still got the error. Then I started commenting out lines until I could isolate the offending part. The part that makes it fail is in the edge list. If I just execute the first simpleSpline it works. In fact it even works with the original grading (as expected since the grading looks correct). However the next simpleSpline edge causes the error. I dont know why the edge type would effect the face between blocks 0 and 1. The edge being splined is not along that face. I tried many ways to get around this problem. I used a polyLine instead of a simpleSpline. This worked sometimes, but sometimes the polyLine would fail also with the same error message. I tried reordering the points. I tried making the domain symetric, I tried reordering the edges. Nothing worked except removing the non linear edges. I hope someone can help. This blockMesh tool looks like just the ticket to do some good 2d airfoil analysis. Thanks. - Dave - |
Hi everyone,
I've got a similar problem (or so I think)... I'm trying to run a simulation of flow through a wind tunnel, and it worked in 2D, so I'm now trying to run it in 3D. BlockMeshDict: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.01; vertices ( (105 0 0) //0 (150 0 0) //1 (150 30 0) //2 (105 30 0) //3 (105 0 0.01) //4 (150 0 0.01) //5 (150 30 0.01) //6 (105 30 0.01) //7 (300 -10 0) //8 (300 40 0) //9 (300 -10 0.01) //10 (300 40 0.01) //11 (350 -10 0) //12 (350 40 0) //13 (350 -10 0.01) //14 (350 40 0.01) //15 (90 0 0) //16 (90 30 0) //17 (90 0 0.01) //18 (90 30 0.01) //19 (80 -1.2 0) //20 (80 31.2 0) //21 (80 -1.2 0.01) //22 (80 31.2 0.01) //23 (70 -4.8 0) //24 (70 34.8 0) //25 (70 -4.8 0.01) //26 (70 34.8 0.01) //27 (60 -10.8 0) //28 (60 40.8 0) //29 (60 -10.8 0.01) //30 (60 40.8 0.01) //31 (50 -19.2 0) //32 (50 49.2 0) //33 (50 -19.2 0.01) //34 (50 49.2 0.01) //35 (40 -30 0) //36 (40 60 0) //37 (40 -30 0.01) //38 (40 60 0.01) //39 ); blocks ( hex (0 1 2 3 4 5 6 7) (45 30 30) simpleGrading (1 1 1) hex (1 8 9 2 5 10 11 6) (150 30 30) simpleGrading (1 1 1) hex (8 12 13 9 10 14 15 11) (50 30 30) simpleGrading (1 1 1) hex (16 0 3 17 18 4 7 19) (15 30 30) simpleGrading (1 1 1) hex (20 16 17 21 22 18 19 23) (10 30 30) simpleGrading (1 1 1) hex (24 20 21 25 26 22 23 27) (10 30 30) simpleGrading (1 1 1) hex (28 24 25 29 30 26 27 31) (10 30 30) simpleGrading (1 1 1) hex (32 28 29 33 34 30 31 35) (10 30 30) simpleGrading (1 1 1) hex (36 32 33 37 38 34 35 39) (10 30 30) simpleGrading (1 1 1) ); edges ( // arc 38 39 (40 15 45.01) arc 36 37 (40 15 -45) // arc 34 35 (50 15 34.21) arc 32 33 (50 15 -34.2) // arc 30 31 (60 15 25.81) arc 28 29 (60 15 -25.8) // arc 26 27 (70 15 19.81) arc 24 25 (70 15 -19.8) // arc 22 23 (80 15 16.21) arc 20 21 (80 15 -16.2) // arc 18 19 (90 15 15.01) arc 16 17 (90 15 -15) // arc 4 7 (105 15 15.01) arc 0 3 (105 15 -15) // arc 5 6 (150 15 15.01) arc 1 2 (150 15 -15) // arc 10 11 (300 15 25.01) arc 8 9 (300 15 -25) // arc 14 15 (350 15 25.01) arc 12 13 (350 15 -25) ); patches ( patch outlet ( (12 14 15 13) ) patch inlet ( (36 38 39 37) ) wall upperWall ( (3 7 6 2) (2 6 11 9) (9 11 15 13) (17 19 7 3) (21 23 19 17) (25 27 23 21) (29 31 27 25) (33 35 31 29) (37 39 35 33) ) wall lowerWall ( (0 4 5 1) (1 5 10 8) (8 10 14 12) (16 18 4 0) (20 22 18 16) (24 26 22 20) (28 30 26 24) (32 34 30 28) (36 38 34 32) ) wall BackWall ( (0 1 2 3) (1 8 9 2) (8 12 13 9) (16 0 3 17) (20 16 17 21) (24 20 21 25) (28 24 25 29) (32 28 29 33) (36 32 33 37) ) symmetryPlane Front ( (4 5 6 7) (5 10 11 6) (10 14 15 11) (18 4 7 19) (22 18 19 23) (26 22 23 27) (30 26 27 31) (34 30 31 35) (38 34 35 39) ) ); mergePatchPairs ( ); // ************************************************** *********************** // Running BlockMesh, I get: Creating block offsets Creating merge list Programme terminated with errors: exit code 1, status 0. Error messages: Inconsistent point locations between block pair 4 and 5 probably due to inconsistent grading. From function blockMesh::createMergeList() in file C:\tmp\OpenFOAM-1.5\applications\utilities\mesh\generation\blockMe sh\createMergeList.C at line 279. FOAM exiting By commenting out lines, i found that the problem is this arc: arc 24 25 (70 15 -19.8) When i comment that line out, BlockMesh worked... I also tried running it without the symmetry plane, and got the same result...same error, and it worked when i commented the arcs at x=70 out... I'm using a windows port of OpenFOAM if that helps :) |
I do not see a problem with above blockMeshDict in 16x - have you tried a later (than 15) version?
Thanks, Mattijs |
I'm having the same problem (in the 1.6 version)... Code:
convertToMeters 0.001; I'm using prism -when defining blocks- in order to get ride off the problems of mergePatchPairs. If a proper hex is created (hex (1 4 5 6 12 15 16 17 )) and the lines of mergePatchPairs are uncommented "all the faces of the patch are merged, then the patch itselfs will contain NO FACES and is removed" and this removes the points of the edge that share with another faces, letting this face (created during the blockMesh) with only "2 points" -error I've already gotten-. If I'm right (if not, PLEASE correct me) the best solution would be add some lines in the blockMesh.C (or mergePatchPairs?) utility code to check if a face shares edges with faces of other patches and don't delete them during the merging process. I don't know how to do this but I would be very grateful if this could be fixed. Thanks in advance! Juanma |
This is fixed in OpenFOAM-1.6.x which you can download from our git repository.
H |
Inconsistent point locations between pair
Hi, I'm using OpenFOAM V2.1 and facing the same problem as below.
Creating block mesh from Thanks. |
FYI for future readers: kyushusamurai found the solution here: http://www.cfd-online.com/Forums/ope...anslation.html
