Home > Forums > OpenFOAM Bugs
ParaFoam error missing libPVFoamReaderso
Old   April 28, 2008, 09:43
Default Hi, After having successful
Alexander Grahn
agrahn is on a distinguished road
After having successfully compiled OpenFOAM-1.4.1 on a Gentoo box, I am trying to get started by going through the first tutorial `lid driven cavity'.
In section 2.1.2 it is suggested to have a look at the mesh, running paraFoam. Unfortunately paraFoam crashes (see below).
What now? Help is greatly appreciated.
Alexander
grahn@fwss41:~/OpenFOAM/OpenFOAM-1.4.1 $ paraFoam $FOAM_RUN/tutorials/icoFoam cavity
ErrorMessage
# Error or warning: ERROR: In /home/dm2/henry/OpenFOAM/linuxSrc/paraview-2.4.4/Utilities/VTKClientServer/vtkCl ientServerInterpreter.cxx, line 866
vtkClientServerInterpreter (0x80664b8): Cannot find module "libPVFoamReader.so". The following paths were searched:
/home/grahn/OpenFOAM/linux/paraview-2.4.4/lib/paraview-2.4
/home/grahn/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/openmpi-1.2.3
/home/grahn/OpenFOAM/OpenFOAM-1.4.1/src/openmpi-1.2.3/platforms/linuxGccDPOpt/li b
/home/grahn/OpenFOAM/grahn-1.4.1/lib/linuxGccDPOpt
/home/grahn/OpenFOAM/linux/paraview-2.4.4/bin
/home/grahn/OpenFOAM/OpenFOAM-1.4.1/src/openmpi-1.2.3/platforms/linuxGccDPOpt/bi n
/home/grahn/OpenFOAM/OpenFOAM-1.4.1/src/mico-2.3.12/platforms/linuxGccDPOpt/bin
/home/grahn/.gentoo/java-config-2/current-user-vm/bin
/home/grahn/OpenFOAM/grahn-1.4.1/applications/bin/linuxGccDPOpt
/home/grahn/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt
/home/grahn/OpenFOAM/OpenFOAM-1.4.1/wmake
/home/grahn/OpenFOAM/OpenFOAM-1.4.1/bin
/home/grahn/bin
/usr/local/bin
/usr/kde/3.5/bin
/usr/bin
/bin
/opt/bin
/usr/i686-pc-linux-gnu/gcc-bin/4.1.2
/opt/sun-jdk-1.4.2.17/bin
/opt/sun-jdk-1.4.2.17/jre/bin
/opt/sun-jdk-1.4.2.17/jre/javaws
/usr/qt/3/bin
/usr/lib
/usr/lib/vtk
/usr/local/lib
/usr/local/lib/vtk
ERROR: In /home/dm2/henry/OpenFOAM/linuxSrc/paraview-2.4.4/GUI/Client/vtkPVXMLPackageParse r.cxx, line 678
vtkPVXMLPackageParser (0x8957870): Error loading Library component PVFoamReader
ErrorMessage end
ErrorMessage
# Error or warning: There was a VTK Error in file: /home/dm2/henry/OpenFOAM/linuxSrc/paraview-2.4.4/GUI/Client/vtkPVWindow.cxx (2366)
vtkPVWindow (0x825a5f8): Cannot read file information when no reader is specified. This probably means that the reader for the file with name: /home/grahn/OpenFOAM/grahn-1.4.1/run/tutorials/icoFoam/cavity/cavity.foam cannot be found
ErrorMessage end
ErrorMessage
# Error or warning: There was a VTK Error in file: /home/dm2/henry/OpenFOAM/linuxSrc/paraview-2.4.4/GUI/Widgets/vtkKWApplication.cx x (1335)
vtkPVApplication (0x80d4c10):
Script:
paraFoam.pvs
Returned Error on line 11:
invalid command name ""
ErrorMessage end
agrahn is offline   Reply With Quote
Old   April 28, 2008, 19:19
Default Hi Alexander Please search
jaswi is on a distinguished road
Hi Alexander
Please search the forum under the section installation or with your error message and you will find a large number of posts discussing why this happens and what you can do to solve the problem.
Search for Håkan Nilsson's phd course on google. He has somt tips on how to successfully install paraFoam/paraview
Hope that Helps
Jaswi
jaswi is offline   Reply With Quote
Old   June 21, 2008, 16:52
Default When I start paraFoam and hit
musaddeque hossein
musahossein is on a distinguished road
When I start paraFoam and hit the accept button to load the mesh for cavity.foam, I get the following error. Any suggestions / advice how to fix tis would be appreciated.
musa@linux:~> paraFoam $FOAM_RUN/tutorials/icoFoam cavity
--> FOAM FATAL IO ERROR : attempt to read beyond EOF
file: /home/musa/OpenFOAM/musa-1.4.1/run/tutorials/icoFoam/cavity/0/U::internalField at line 30.
From function ITstream::read(token& t)
in file db/IOstreams/Tstreams/ITread.C at line 70.
FOAM exiting
musahossein is offline   Reply With Quote
Old   June 23, 2008, 12:34
Default I solved the problem (for alwa
musaddeque hossein
I solved the problem (for always I hope) by reloading the tutorials. It appears to works now.
Thread Tools
Trackbacks are On
ParaFoam error with raw chegdan OpenFOAM Bugs 2 July 18, 2009 14:47
Error in paraFoam mattlee OpenFOAM Paraview & paraFoam 2 June 29, 2009 15:36
Error in paraFoam mattlee OpenFOAM Installation 0 March 1, 2009 22:34
ParaFoam Error navaladi OpenFOAM Paraview & paraFoam 13 April 22, 2008 16:01
Missing library libPVFoamReaderso dirk_kehrwald OpenFOAM Paraview & paraFoam 3 July 19, 2006 06:50
