Irritating TYPO in updateFromRepositoryAndCompilesh trashes source |
April 29, 2008, 23:07 |
Description:
Ugh. Copies of u
Andrew Burley
Rep Power: 17 |
Description:
Ugh. Copies of updateFromRepositoryAndCompile.sh in both /branches/OpenCFD_Release/OpenFOAM-1.4.1_patch and /branches/OpenCFD_Release/OpenFOAM-1.4_patch have a typo that will ensure your local working copy is useless and WON'T compile: Reads (in the case of OpenFOAM-1.4.1_patch) on line 5: svn diff -r30 --diff-cmd diff -x "--unified=7"......... "-r30"?????!!! The file this is in isn't even revision 30. Some untouched files are still Rev 30, but all useful patches are in the triple digits. Solver/Application: Since we're after the latest patches submitted to this repo. section, why not use HEAD? Therefore PATCH LINE 5 of updateFromRepositoryAndCompile.sh in BOTH OpenFOAM-1.4_patch and OpenFOAM-1.4.1_patch to read: svn diff -r HEAD --diff-cmd diff -x "--unified=7" https://openfoam-extend......etcetc Versions: Affects SVN patch branches: /branches/OpenCFD_Release/OpenFOAM-1.4.1_patch /branches/OpenCFD_Release/OpenFOAM-1.4_patch Notes: This lil' critter-beast pre-vented a shucsheshful compilatorium on thayt there computah-gizmo-whatzit. Supposin' now I can bes checkin' this 'ere software out somethun speshul-like... |
April 29, 2008, 23:34 |
Whoops! Made a boo-boo myself:
Andrew Burley
Rep Power: 17 |
Use: svn diff -r HEAD:30 --diff-cmd diff -x "--unified=7" https://openfoam-exten.... for 1.4.1_patch and svn diff -r HEAD:6 --diff-cmd diff -x "--unified=7" https://openfoam-exten.... for 1.4_patch Sorry, my bad. Think I've got it right now... trying to patch now.. if it doesn't work I'll get the full SVN, but I'll post here to let y'all know how I went... |
April 30, 2008, 02:05 |
Looks like I got it back-the-f
Andrew Burley
Rep Power: 17 |
Looks like I got it back-the-front. Using HEAD:30 just ensured I was at Revision 30. svn log -r HEAD:30 outputs change logs from newest to oldest, whilst 30:HEAD outputs change logs from oldest to newest...
So now I'm trying: svn diff -r 30:HEAD --diff-cmd diff -x "--unified=7" https://openfoam-exten..... I'll let you know how I fared... |
April 30, 2008, 04:23 |
Yep, that seems to have done t
Andrew Burley
Rep Power: 17 |
Yep, that seems to have done the trick.
SO: svn diff -r 30 --diff-cmd....... doesn't update to the latest revision. in updateFromRepositoryAndCompile.sh : for 1.4.1_patch: change: svn diff -r 30 --diff-cmd... to: svn diff -r 30:HEAD --diff-cmd.... and for 1.4_patch: change: svn diff -r 6 --diff-cmd... to: svn diff -r 6:HEAD --diff-cmd... This essentially says "collect all differences between revision 6 and the HEAD revision, and calculate the diff strings relative to my local source, for the intent of upgrading towards HEAD revision". Sorry about the mix-up earlier, but now I'm happy and compiling away with the latest HEAD of the bugfix patches. |
April 30, 2008, 08:40 |
Hi!
I was under the impress
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi!
I was under the impression that -r 30 implies -r 30:HEAD (at least it works for me). Maybe this is an issue with different versions of the svn-client. I will change this in the svn(as soon as the sourceforge.net comes back online - currently I can't reach it) Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
Display Modes | |
contribution of convective source in total source? | Antony | Phoenics | 4 | July 30, 2008 06:15 |
Volumetric source or Inlet source | Kumar | CFX | 0 | May 12, 2008 10:33 |
Source and Source coefficient | Ramcharan | CFX | 0 | February 13, 2008 08:27 |
SOURCE!-b.c. | Louisa | FLUENT | 0 | September 3, 2007 15:07 |
Mixture-model typo in FLUENT6.2 documentation? | George Gerber | FLUENT | 1 | June 19, 2006 13:10 |
