-   OpenFOAM Bugs (http://www.cfd-online.com/Forums/openfoam-bugs/)
-   -   Bug of backwardDdtScheme (http://www.cfd-online.com/Forums/openfoam-bugs/62507-bug-backwardddtscheme.html)
liuhuafei January 21, 2008 02:39
File: backwardDdtScheme.c Fun
Function:
template<class>
tmp<geometricfield<type,> >
backwardDdtScheme<type>::fvcDdt
const volScalarField& rho,
const GeometricField<type,>& vf
rDeltaT.value()*( coefft*vf.boundaryField() -
(coefft0*rho.oldTime().boundaryField() *vf.oldTime().boundaryField()
- coefft00*rho.oldTime().oldTime().boundaryField()
*vf.oldTime().oldTime().boundaryField()
where is rho.boundaryField()
henry January 21, 2008 04:20
Yes you are quite right rho.bo
Yes you are quite right rho.boundaryField() should be in coefft*vf.boundaryField() , i.e.
coefft*rho.boundaryField()*vf.boundaryField()
Thanks for reporting it
Henry
liuhuafei January 21, 2008 20:05
Dr Henry Weller, Thanks for
Dr Henry Weller,
Thanks for your answer. I am checking the source code. I am happy that I will find a bug in the foam. Maybe the foam will be bug-free in the future.
Another thing. Could you kindly explain something I don't understand. See my post,
http://www.cfd-online.com/cgi-bin/Op...cus/discus.cgi
Liu Huafei
liuhuafei January 23, 2008 20:15
Dr Henry Weller, Thanks for y
Dr Henry Weller,
Thanks for your answer. Could you kindly explain something I don't understand.
post,
Some questions about the implementation of the convection scheme
By Liu Huafei on Sunday, January 20, 2008 - 05:18 pm: Edit Post
It seems that something wrong with the implementation of the convection scheme. I guess the face value is based on the following formula
&Phi;f =&Phi;C +(xf &ndash; xC) *&psi;(rf) * (d&Phi;/ dx)f
Or
&Phi;f =&Phi;C +(xf &ndash; xC) / (xD&ndash; xC) *&psi;(rf) * (&Phi;D-&Phi;C)
f ,the face
C,central node
D downwind node
&psi;(rf) the flux limiter
rf is based on the following formula
rf=(&Phi;C-&Phi;U)/( &Phi;D-&Phi;C) = 2*grad(&Phi;C)*(xD-xC) /( &Phi;D-&Phi;C) -1
so
for the faceflux mf
mf>0 &Phi;f =&Phi;P+fx*&psi;(rf) * (&Phi;N-&Phi;P)
=(1-fx*&psi;(rf)) &Phi;P +f x*&psi;(rf)* &Phi;N
mf<0 &Phi;f =&Phi;N+(1-fx)*&psi;(rf) * (&Phi;P-&Phi;N)
=(1-fx) *&psi;(rf)* &Phi;P +[1-(1-fx) *&psi;(rf)]* * &Phi;N
fx is the geometric interpolation factor, defined by fx=(xN-xf)/(xN-xP)
P is owner cell
N is neighbour cell
but in the limitedSurfaceInterpolationScheme.H and limitedSurfaceInterpolationScheme.c
template<class>
tmp<surfacescalarfield> limitedSurfaceInterpolationScheme<type>::weights
const GeometricField<type,>& phi
) const
const fvMesh& mesh = this->mesh();
tmp<surfacescalarfield> tWeights(this->limiter(phi)); this is&psi;(rf)!!!!!!!
surfaceScalarField& Weights = tWeights();
const surfaceScalarField& CDweights = mesh.surfaceInterpolation::weights(); fx !!!! scalarField& pWeights = Weights.internalField();
forAll(pWeights, face){
pWeights[face] = pWeights[face]*CDweights[face]
+ (1.0 - pWeights[face])*pos(faceFlux_[face]); It is right??????
Maybe openfoam is based on other formula. Could you kindly explain clearly it?
henry January 24, 2008 04:04
I don't see the problem. The
I don't see the problem. The only thing in the code which may be confusing is the reuse of Weights, it is first used to store the limiter field and then becomes the weights field because after each face-weight is calculated the corresponding limiter value is no longer needed. I can add a comment on this if you think it would be useful.
Henry
liuhuafei January 24, 2008 21:07
liuhuafei January 27, 2008 20:41
If convection scheme is done b
If convection scheme is done by such way,some contradiction arises.
LDUMatrix contains the coefficients, lowerPtr,upperPtr,diagPtr ,and
the address reference, uPtr and lPtr. The upperPtr stores the contribution
of the neighbour cell(N) to the owner cell(P) and the lowerPtr store
the contribution of the owner(P) to the neighbour(N).
For upwind scheme, &Phi;f =max(mf,0)/mf * &Phi;P +min(mf,0)/mf * &Phi;N, so in upwind.h
the weight factor is calculated by
tmp<surfacescalarfield> weights() const
return pos(this->faceFlux_);
It is OK. From this code,I guess the weight is corresponding to the following code
fvm.lower() = -weights.internalField()*faceFlux.internalField();
fvm.upper() = fvm.lower() + faceFlux.internalField();
fvm.negSumDiag();
fvm.lower is the contribution of the owner(P) to the neighbour(N),fvm.upper
the contribution of the neighbour(N) to the owner(P).
But for the high order convection scheme,
mf>0 &Phi;f =&Phi;P+fx*&psi;(rf) * (&Phi;N-&Phi;P) = (1-fx*&psi;(rf)) &Phi;P +f x*&psi;(rf)* &Phi;N
mf<0 &Phi;f =&Phi;N+(1-fx)*&psi;(rf) * (&Phi;P-&Phi;N) = (1-fx) *&psi;(rf)* &Phi;P +[1-(1-fx) *&psi;(rf)]* &Phi;N
It is right? It is corresponding to the fvm.upper rather than fvm.lower,why?
fvm.lower is not the contribution of P to N?
Another question: Diag[i] should be substract the contribution from
all its neighbouring cell.
In fvMatrix, the implementation of function negSumDiag() is as follows
negSumDiag:
for (register label face=0; face<l.size(); face++)
Diag[l[face]] -= Lower[face]; // AP[IP]=AP[IP]-AL[IFF] is correct??????
Diag[u[face]] -= Upper[face]; // AP[IN]=AP[IN]-AU[IFF] is correct??????
why not the following code?
Diag[l[face]] -= Upper[face]; (Upper is the contribution of N to P)
Diag[u[face]] -= Lower[face]; (Lower is the contribution of P to N)
Liu Huafei
