Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Libcso6 version %60GLIBC_234b
Old   January 24, 2008, 06:29
Default Hi, I am trying to run Open
John Deas
johndeas is on a distinguished road
I am trying to run OpenFOAM on a Red Hat Entreprise Linux 3, blockMesh and icoFoam run fine on the cavity case, but when I tried to run decomposePar to solve it across several nodes, I get :
decomposePar: /lib/tls/libc.so.6: version `GLIBC_2.3.4' not found (required by /home/flurec/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libGKlib.so)
Has anyone get through this problem ? I haven't had it on Centos 5.1 or Ubuntu 7.10 ...
I also tried to run wmake in the decomposePar directory, but I got errors while it compile /tmp/ccLhuesa.s
johndeas is offline   Reply With Quote
Old   January 24, 2008, 06:35
Default And, if I run decomposePar on
John Deas
And, if I run decomposePar on another machine, and then launch icoFoam in parallel on the RHEL 3 machine, I get this message :
mca: base: component_find: unable to open paffinity linux: file not found (ignored)
... but the computation runs anyway and output results. Is this a severe default ?
Old   January 24, 2008, 08:46
Default RHEL 3 uses glibc_2.3.2 Upg
Eugene de Villiers
eugene is on a distinguished road
Upgrade your OS it is nearly 5 years old.
The only other alternative is to recompile everything including 3rd party components like gcc from scratch.
eugene is offline   Reply With Quote
Old   January 24, 2008, 09:03
Default Maybe relinking is sufficient.
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Maybe relinking is sufficient. It's faster. But recompiling is safer.
(Problem is, that still RHEL3 seems to be quite popular with clusters)
BTW: Relinking: just remove everything in $FOAM_LIBBIN and $FOAM_APPBIN and Allwmake.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   January 24, 2008, 10:04
Default Er, even if you leave everythi
Eugene de Villiers
Er, even if you leave everything in $FOAM_LIBBIN and $FOAM_APPBIN, executing Allwmake on a clean distribution will still trigger a complete recompile since the intermediate .o files are stripped out before release.
I think you have recompiled your own distro once to often!
Old   January 24, 2008, 10:06
Default You can use ermine (http://mag
Valery Reznic
valery_reznic is on a distinguished road
You can use ermine (http://magicErmine.com) or statifier (http://statifier.sf.net) to pack program on system where it's work (Ubuntu) and them move packed executable to the "box in question"
Valery
valery_reznic is offline   Reply With Quote
Old   January 24, 2008, 11:02
Default The same thing happened for me
N S Prasad
nsp82 is on a distinguished road
The same thing happened for me in RHEL 3. I haven't solved the problem yet....
nsp82 is offline   Reply With Quote
Old   January 24, 2008, 11:33
Default @Eugene: you're partly right:
Assistant Moderator
Bernhard Gschaider
@Eugene: you're partly right: I compiled it twice to often.
I pull back my post. Recompiling is ALWAYS the solution. And do it on the system with the lowest version number. Then the binaries should propably be compatible to all the others. (Assuming you only have distros from the same "family". If for instance you have a zoo of RedHat and Ubuntu boxes: Use the one with the lowest glibc)
Old   January 24, 2008, 12:01
Default I really dislike glibc - nothi
Eugene de Villiers
I really dislike glibc - nothing technical, just on a personal level.
Re static linking: Since OpenFOAM has more than a hundred executables, linking them all statically would use quite a lot of disk space.
Old   January 24, 2008, 14:13
Default Thank all for your advices.
John Deas
New version fluent file open in Old version ? MANOJKUMAR FLUENT 2 July 10, 2013 04:43
which version star Siemens 3 January 14, 2009 04:19
Difference between Version 6.3 and Version 6.2 erikaj FLUENT 0 October 11, 2007 12:36
GLIBC libcso6 fred OpenFOAM Installation 2 April 12, 2006 11:11
Version 3.5 David Lloyd Phoenics 1 August 7, 2002 09:22
