-   OpenFOAM Bugs (http://www.cfd-online.com/Forums/openfoam-bugs/)
-   -   Problem with foam utilities in foamx (http://www.cfd-online.com/Forums/openfoam-bugs/62511-problem-foam-utilities-foamx.html)
alan_fergus January 14, 2008 09:36
hi, i just reinstalled OpenFo
hi,
i just reinstalled OpenFoam 1.3 on fedora core 8, everything seems to be fine.
Checking basic setup...
Shell: bash
Host: localhost.localdomain
OS: Linux version 2.6.23.9-85.fc8
User: alan
User_config: /home/alan/.bashrc
Foam_config: /home/alan/.OpenFOAM-1.3/bashrc sourced correctly.
Checking main FOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/alan/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/alan/OpenFOAM/alan-1.3 yes no
$FOAM_JOB_DIR /home/alan/OpenFOAM/jobControl no yes
Checking the FOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/alan/OpenFOAM/OpenFOAM-1.3 yes yes yes
$FOAM_USER_APPBIN ...-1.3/applications/bin/linuxGcc4DPOpt yes yes no
$FOAM_APPBIN ...-1.3/applications/bin/linuxGcc4DPOpt yes yes yes
$WM_DIR /home/alan/OpenFOAM/OpenFOAM-1.3/wmake yes yes yes
$FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes
$CEI_HOME /usr/local/ensight/CEI no no
$JAVA_PATH /usr yes yes no
$MICO_ARCH_PATH ...mico-2.3.11/platforms/linuxGcc4DPOpt yes yes yes
$LAM_ARCH_PATH ...c/lam-7.1.1/platforms/linuxGcc4DPOpt yes yes yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...FOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt yes yes yes
$FOAM_USER_LIBBIN ...OpenFOAM/alan-1.3/lib/linuxGcc4DPOpt yes yes no
Software versions
Software Version Location
gcc 4.1.2 /usr/bin/gcc
java 1.7.0 /usr/bin/java
gzip 1.3.12 /usr/bin/gzip
tar 1.3.12 /bin/tar
icoFoam ...M/OpenFOAM-1.3/applications/bin/linuxGcc4DPOpt/icoFoam
Checking file/directory permissions...
File/directory Set Reqd Crit
Checking networking...
Action Result Crit
...localhost.localdomain Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the Foam enviroment.
Base configuration ok.
Critical systems ok.
[alan@localhost bin]$
and running the cases on the command line works fine but when i go into a case in foamx the foam utilities menu will not appear.
i was wondering has anyone come across this and may have a solution to it. its not the end of the world but i would prefer to be able to run blockmesh etc from foamx rather than having to do it on the command line
david_flo1 January 14, 2008 13:55
I am no expert but it happened
I am no expert but it happened to me on OF 1.4.1 and I solved it by installing sun java jre and dev using the package manager in Ubuntu. Obviously you have do the modifications to the OpenFOAM's .bash file as the test finds java under usr/bin, which is ok.
Hope this helps.
Bernardo
alan_fergus January 15, 2008 07:38
thanks that worked
thanks that worked
