-   OpenFOAM Bugs (http://www.cfd-online.com/Forums/openfoam-bugs/)
-   -   Who can help me (http://www.cfd-online.com/Forums/openfoam-bugs/62520-who-can-help-me.html)
ivanyao December 20, 2007 12:00
hi when i do the Tutorials'
hi
when i do the Tutorials's case(cavity).when i type "paraFoam $FOAM RUN/tutorials/icoFoam cavity" ,the Paraview is appear,when i click "Accept".the Paraview is exit!And appear some errorhttp://www.cfd-online.com/OpenFOAM_D...lipart/sad.gifas show below)
FOAM FATAL IO ERROR:attempt to read beyond EOF
File:././o/u::Value at Line 37
From Funtion ITstream::read(token$.t) in file db/IOstream/ITread.c at Line 70.
what can i do?
ivanyao December 20, 2007 12:06
i forget to tell something,i u
i forget to tell something,i use the openfoam1.4.and the Paraview2.4.4.is it ok?
shu December 20, 2007 12:21
Check the file u, perhaps you
Check the file u, perhaps you have to fix it up.
Good luck!
ivanyao December 20, 2007 20:52
file u?how to find it?And how
file u?how to find it?And how to fit it up?
jaswi December 21, 2007 06:24
Hi Weihang Please take a lo
Hi Weihang
Please take a look at the general structure of a case setup. Chapter 4 of the user guide explains that in enough detail.
For now look into the your case directory and u will find three folders:
<case>/0/ <<-----contains boundary and initial conditions for the field variables for which u r seeking solution eg p , U,
<case>/constant/
<case>/system/
Please read the details of what other folders contain in the user guide. Believe me it has mostly all the information for a good start.
In you case the file <case>/0/U needs to be taken case of.
Hope that helps .
Regards
Jaswinder
