Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Who can help me
Old   December 20, 2007, 11:00
Default hi when i do the Tutorials'
weihong yao
ivanyao is on a distinguished road
hi
when i do the Tutorials's case(cavity).when i type "paraFoam $FOAM RUN/tutorials/icoFoam cavity" ,the Paraview is appear,when i click "Accept".the Paraview is exit!And appear some erroras show below)
FOAM FATAL IO ERROR:attempt to read beyond EOF
File:././o/u::Value at Line 37
From Funtion ITstream::read(token$.t) in file db/IOstream/ITread.c at Line 70.
what can i do?
ivanyao is offline   Reply With Quote
Old   December 20, 2007, 11:06
Default i forget to tell something,i u
weihong yao
i forget to tell something,i use the openfoam1.4.and the Paraview2.4.4.is it ok?
Old   December 20, 2007, 11:21
Default Check the file u, perhaps you
shu
Bitan SHU
shu is on a distinguished road
Check the file u, perhaps you have to fix it up.
Good luck!
shu is offline   Reply With Quote
Old   December 20, 2007, 19:52
Default file u?how to find it?And how
weihong yao
file u?how to find it?And how to fit it up?
Old   December 21, 2007, 05:24
Default Hi Weihang Please take a lo
jaswi is on a distinguished road
Hi Weihang
Please take a look at the general structure of a case setup. Chapter 4 of the user guide explains that in enough detail.
For now look into the your case directory and u will find three folders:
<case>/0/ <<-----contains boundary and initial conditions for the field variables for which u r seeking solution eg p , U,
<case>/constant/
<case>/system/
Please read the details of what other folders contain in the user guide. Believe me it has mostly all the information for a good start.
In you case the file <case>/0/U needs to be taken case of.
Hope that helps .
Regards
Jaswinder
jaswi is offline   Reply With Quote
