-   OpenFOAM Bugs (http://www.cfd-online.com/Forums/openfoam-bugs/)
-   -   Canbt install on Suse 102 (http://www.cfd-online.com/Forums/openfoam-bugs/62527-canbt-install-suse-102-a.html)
klausb December 1, 2007 15:11
I am using Suse Linux 10.2 wit
I am using Suse Linux 10.2 with the latest online updates on an Intel Core2
I tried to install OpenFoam according to the instructions found on http://www.opencfd.co.uk/openfoam/linux.html and encountered two problems:
1. The files ending .gtgz can't be extracted > basically resolved by renaming the file ending to .tgz
2. When I try to extract all the installation files in the suggested file structure $HOME/OpenFoam/linux as described on http://www.opencfd.co.uk/openfoam/linux.html, the files OpenFOAM-1.4.1.linuxGccDPOpt.gtgz and OpenFOAM-1.4.1.linuxGccSPOpt.gtgz can't be extracted after OpenFOAM-1.4.1.General.gtgz (all these files now ending .tgz so they can be extracted at all) producing an error message "mv: moving „/home/user/OpenFoam/OpenFOAM-1.4.1.linuxGccDPOpt.tgz_FILES/OpenFOAM-1.4.1" to „/home/user/OpenFoam/OpenFOAM-1.4.1" not possible: The directory is not empty
What can I do about it?
Klaus
santos December 1, 2007 21:05
Hi The steps I usually do t
Hi
The steps I usually do to install OpenFOAM are:
mkdir ~/OpenFOAM
mkdir ~/OpenFOAM/linux
copy OpenFOAM-1.4.1* files to OpenFOAM, and gcc, paraview and java to linux
cd ~/OpenFOAM
tar xzf OpenFOAM-1.4.1.General.gtgz
tar xzf OpenFOAM-1.4.1.linuxGccDPOpt.gtgz
cd ~/OpenFOAM/linux
tar xzf gcc*
tar xzf paraview*
tar xzf java*
edit ~/.bashrc and add at the bottom of the file:
. /home/jose/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc
With this, OpenFOAM is up and running. Please re-try your installation, and tell us if you solved your problem.
Regards,
Josť Santos
