Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Failed dimensional check with dynamic LES models
Old   June 7, 2007, 08:47
Default Description: Running channelOo
Alberto Passalacqua
Description: Running channelOodles (OF 1.4) on the tutorial case, enabling a LES model which uses the dynamic procedure gives dimensional check errors like the following:
- With dynSmagorinsky
--> FOAM FATAL ERROR : Different dimensions for =
dimensions : [0 2 -1 0 0 0 0] = [0 1 0 0 0 0 0]
#0 Foam::error::printStack(Foam:stream&)
#1 Foam::error::abort()
#2 Foam::dimensionSet::operator=(Foam::dimensionSet const&) const
#3 Foam::GeometricField<double,>::operator=(Foam::tmp <foam::geometricfield<double,> > const&)
#4 Foam::LESmodels::dynSmagorinsky::correct(Foam::tmp <foam::geometricfield<foam::te nsor<double>, Foam::fvPatchField, Foam::volMesh> > const&)
#5 Foam::LESmodel::correct()
#6 main
#7 __libc_start_main
#8 __gxx_personality_v0 at /usr/src/packages/BUILD/glibc-2.3/csu/../sysdeps/x86_64/elf/start.S:116
From function dimensionSet::operator=(const dimensionSet& ds) const
in file dimensionSet/dimensionSet.C at line 156.
- With dynOneEqEddy
--> FOAM FATAL ERROR : incompatible dimensions for operation
[k[0 1 -2 0 0 0 0] ] - [((2*nuSgs)*magSqr(symm(grad(U))))[0 2 -3 0 0 0 0] ]#0 Foam::error::printStack(Foam:stream&)
#2 void Foam::checkMethod<double>(Foam::fvMatrix<double> const&, Foam::GeometricField<double,> const&, char const*)
#3 Foam::tmp<foam::fvmatrix<double> > Foam::operator-<double>(Foam::GeometricField<double,> const&, Foam::tmp<foam::fvmatrix<double> > const&)
#4 Foam::LESmodels::dynOneEqEddy::correct(Foam::tmp<f oam::geometricfield<foam::tens or<double>, Foam::fvPatchField, Foam::volMesh> > const&)
#6 main
From function checkMethod(const fvMatrix<type>&, const GeometricField<type,>&)
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.4/src/finiteVolume/lnInclude/fvMatrix.C at line 1042.
FOAM aborting
Solver/Application: LESModels classes
Source file:
Testcase: channel395 with a LES model using the dynamic procedure.
Platform: All
Version: 1.4
Regards,
Alberto
Alberto Passalacqua
Old   June 10, 2007, 13:07
Default Any clue on this one? Or am I
Alberto Passalacqua
Any clue on this one? Or am I missing something straightforward? :-?
Thanks in advance,
A.
Alberto Passalacqua
Old   June 11, 2007, 14:31
Default On line 40 of OpenFOAM-1.4/
henry is on a distinguished road
On line 40 of
OpenFOAM-1.4/src/OpenFOAM/fields/GeometricFields/GeometricSymmTensorField/GeometricSymmTensorField.C
replace 'transform' with 'sqr' (corrected version attached GeometricSymmTensorField.C ) and recompile everything.
Henry
henry is offline   Reply With Quote
Old   June 11, 2007, 15:00
Default As always, thanks a lot.
Alberto Passalacqua
Alberto Passalacqua
Old   July 11, 2007, 05:41
Default I am a new user of Linux; I ha
benyahia nabil
nabildjef is on a distinguished road
I am a new user of Linux; I have installed redhat9.0 for install Openfoam-1.3. In installation of Openfoam-1.3 I follow instruction in file readme. But when I start installation of GCC the message is: Permission non accordée.
In installation of redhat I create session her name is nabil, in this session I crest file Open FOAM
To install OpenFOAM, I flowing thus instruction.
The first instruction is: $HOME/OpenFOAM/OpenFOAM-4.1.2/.OpenFOAM-1.3/bashrc
The second instruction is: $WM_PROJECT_INST_DIR/$WM_ARCH/gcc-4.1.2
But here indicate that Permission non accordée.
The same for third instruction, $WM_PROJECT_DIR/.bashrc
After he installs normally openfoam, but in testing the installation indicates tow critical errors and one fatal error
I search
nabildjef is offline   Reply With Quote
Old   July 11, 2007, 05:48
Default please post your message in:
Maka Mohu
maka is on a distinguished road
OpenFOAM Message Board: OpenFOAM: Installation
Have a nice day!
/Maka.
maka is offline   Reply With Quote
Old   August 9, 2007, 06:19
Default Hi OpenFOAM developers Prob
jaswi is on a distinguished road
Problem related to dynSmagorinsky model.
While use the dynSmagorinsky model, the solver throws up the dimension mismatch error.
Forum search shows that the following file has to be fixed:
I did as it suggests and then recompiled the whole thing by executing AllMake located in the
/OpenFOAM/OpenFOAM-1.4/src>
The bottom line is that it still throws the dimension mismatch error.
My guess is that the header file needs to be fixed as well !!!!! because it still contains the old defintion on line 52
Please comment
Regards
Jaswinder
jaswi is offline   Reply With Quote
Old   August 9, 2007, 06:44
Default Have you tried version 1.4.1?
Old   August 9, 2007, 06:48
Default No I am still using the versio
No I am still using the version 1.4.
Old   September 5, 2007, 22:57
Default Great, there's no problem in v
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Great, there's no problem in version 1.4.1
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Grid check failed Norasikin Mat Isa FLUENT 2 August 31, 2011 03:30
Grid check failed Norasikin Mat Isa FLUENT 9 October 11, 2007 03:44
LES dynamic models fail dimensional check alberto OpenFOAM Running, Solving & CFD 0 June 11, 2007 13:23
check grid failed nikita FLUENT 1 July 30, 2003 02:31
Grid check failed Ellen FLUENT 5 June 23, 2000 14:42
