August 9, 2007, 11:14 |
I'm a newcomer, Intel GmbH Ger
Hans-Joachim Plum
Rep Power: 17 |
I'm a newcomer, Intel GmbH Germany, wanting to use OpenFOAM as Cluster benchmark
Using the install "Allwmake", always runs into template definition problems (g++ or Intel icpc) Using g++ SOURCE=fvMeshDistribute/fvMeshDistribute.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-pa rameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/hplum/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolu me/lnInclude -I/home/hplum/OpenFOAM/OpenFOAM-1.4.1/src/meshTools/lnInclude -I/home/hplum/OpenFOAM/OpenFOAM-1.4.1/src/ triSurface/lnInclude -IlnInclude -I. -I/home/hplum/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/fvMeshDistribute.o In file included from fvMeshDistribute/fvMeshDistribute.H:397, from fvMeshDistribute/fvMeshDistribute.C:30: fvMeshDistribute/fvMeshDistributeTemplates.C: In static member function `static void Foam::fvMeshDistribute::sendFiel ds(Foam::label, const Foam::wordList&, const Foam::fvMeshSubset&)': fvMeshDistribute/fvMeshDistributeTemplates.C:299: error: expected primary-expression before '>' token make: *** [Make/linuxGccDPOpt/fvMeshDistribute.o] Error 1 usinf Intel icpc SOURCE=motionSmoother/motionSmoother.C ; icpc -Dlinux -DDP -wd654,819,1125,1476,1505,1572 -ansi-alias -O3 -ftz -fno- alias -fargument-noalias-global -unroll0 -DNoRepository -I/home/hplum/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInc lude -I/home/hplum/OpenFOAM/OpenFOAM-1.4.1/src/meshTools/lnInclude -I/home/hplum/OpenFOAM/OpenFOAM-1.4.1/src/triSurfa ce/lnInclude -IlnInclude -I. -I/home/hplum/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -KPIC -c $SOURCE -o Make/ linuxicpcDPOpt/motionSmoother.o /home/hplum/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/FieldFieldFunctions.C (832): error: no instance of overload ed function "Foam::outer" matches the argument list argument types are: (Foam::pointPatchField<foam::vector>, const Foam::pointPatchField<foam::scalar>, cons t Foam::pointPatchField<foam::vector>) PRODUCT_OPERATOR(outerProduct, *, outer) ^ detected during: instantiation of "void Foam::outer(Foam::FieldField<field,>::type> &, con st Foam::FieldField<field,> &, const Foam::FieldField<field,> &) [with Field=Foam::pointPatchField, Type1= Foam::FieldField<foam::pointpatchfield,>::cmptType ={Foam::VectorSpace<Foam::Vect or<Foam::scalar={Foam::d oubleScalar={double}}>, Foam::scalar={Foam::doubleScalar={double}}, 3>::cmptType={Foam::scalar={Foam::doubleScalar={d ouble}}}}, Type2=Foam::vector]" at line 952 of "/home/hplum/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/GeometricFieldFuncti ons.C" instantiation of "void Foam::outer(Foam::GeometricField<foam::outerproduc t<type1,>::type, PatchFiel d, GeoMesh> &, const Foam::GeometricField<typer,> &, const Foam::GeometricField<Type1, PatchField , GeoMesh> &) [with Type1=Foam::scalar={Foam::doubleScalar={double}}, Type2=Foam::vector, PatchField=Foam::pointPatch Field, GeoMesh=Foam::pointMesh]" at line 952 of "/home/hplum/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/Geometric FieldFunctions.C" instantiation of "Foam::tmp<foam::geometricfield<foam::outerproduct <type1,>::type, PatchField, GeoM esh>> Foam::operator*(const Foam::GeometricField<typer,> &, const Foam::GeometricField<Type1, Pat chField, GeoMesh> &) [with Type1=Foam::scalar={Foam::doubleScalar={double}}, Type2=Foam::vector, PatchField=Foam::poi ntPatchField, GeoMesh=Foam::pointMesh]" compilation aborted for motionSmoother/motionSmoother.C (code 2) |
August 9, 2007, 11:37 |
Which version of g++ are you u
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Which version of g++ are you using?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
August 9, 2007, 11:55 |
g++ 3.4.4.
In the end, I'm
Hans-Joachim Plum
Rep Power: 17 |
g++ 3.4.4.
In the end, I'm after using icpc (Intel's C++); here I'm using V 9.1 and also getting template definition problems, see message above. |
August 13, 2007, 06:11 |
I don't have experience with c
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I don't have experience with current OpenFOAM-versions and 3.x-series of the GNU compilers (I'm using 4.0.1 on my Mac and the distributed version (==4.1) on Linux). From what I've heard your lucky if OF compiles with a 3.x-compiler.
About Intel 9.1: see the release-notes for OpenFOAM 1.4 (that's all the information I have about that)
August 13, 2007, 06:18 |
We haven't compiled OpenFOAM w
Rep Power: 22 |
We haven't compiled OpenFOAM with gcc-3.4.? for sometime so there may be minor problems. We release gcc-4.2.? with OpenFOAM and promote the use of this compiler development.
I have just compiled our OpenFOAM-1.4.2 development version with icpc-10.0 and there were minor problems with compiling a few source files which may also be a problem with OpenFOAM-1.4.1, I will post the fixes shortly. |
August 13, 2007, 06:20 |
You'll need >4 for gcc version
Mattijs Janssens
Rep Power: 26 |
You'll need >4 for gcc version. Intel compiler version 10 has been reported to work ok.
August 13, 2007, 17:30 |
There is some unnecessary temp
Rep Power: 22 |
There is some unnecessary templating in pointPatchFieldFunctions.H which appears to be confusing the Intel C++ compiler, here is a fixed version pointPatchFieldFunctions.H to replace OpenFOAM-1.4.1/src/OpenFOAM/fields/pointPatchFields/pointPatchField/pointPatchFieldFunctions.H which I have tested with icpc-10.0 and now I get a complete clean build with that compiler.
August 14, 2007, 04:45 |
Henry,
thanks, I'll immedia
Hans-Joachim Plum
Rep Power: 17 |
Henry,
thanks, I'll immediately give it a try |
Why the noslip doesnbt work | corenc | OpenFOAM Running, Solving & CFD | 9 | August 26, 2008 07:26 |
Why my code is ok with single processor but doesnbt work in openmpi | xiuying | OpenFOAM Running, Solving & CFD | 0 | November 23, 2007 13:44 |
Why OpenFOAM doesnbt use STL | cornerstone | OpenFOAM Running, Solving & CFD | 0 | December 22, 2006 02:18 |
Why doesnbt the macro forall work for the volVectorField variable | siwen | OpenFOAM Running, Solving & CFD | 2 | February 24, 2006 15:27 |
I meet a net work probleam when i check the install | ztdep | OpenFOAM Installation | 0 | July 16, 2005 08:27 |
