-   OpenFOAM Bugs (http://www.cfd-online.com/Forums/openfoam-bugs/)
-   -   Symbol lookup error in 14 that was not present in 13 (http://www.cfd-online.com/Forums/openfoam-bugs/62566-symbol-lookup-error-14-not-present-13-a.html)
adona058 July 25, 2007 15:44
I have been working with a cus
I have been working with a custom solver for a few months now in 1.3, and recently decided to make the switch to 1.4 so that I can take advantage of the parallel processing capabilities on the cluster where I am doing my research.
I've recompiled the solver and set up the appropriate case files, but each time I try to run the solver via. openFoam 1.4, I get the following error:
phaseFieldFoam: symbol lookup error: phaseFieldFoam: undefined symbol: _ZTIN4Foam19lduCoupledInterfaceE
where phaseFieldFoam is the name of the solver.
I would appreciate any input you might provide on the source of the error.
Thank you.
henry July 25, 2007 16:04
It looks like you haven't reco
It looks like you haven't recompiled for version 1.4 everything your solver needs. Use wclean and wmake on all components of your solver including any custom libraries your solver needs.
