Dear everyone
I am new to o
Dear everyone
I am new to openfoam. I download the openfoam 1.4 and tried to compiled on suse linux 10.1 after fixed it according to the contents on the site http://www.cfd-online.com/OpenFOAM_D...tml?1182157148 but the following errors arised during the compilation -lmeshTools /home/sujunwei/OpenFOAM/OpenFOAM-1.4/applications/utilities/mes h/manipulation/setSet/readline-5.0/platforms/linuxGcc4DPOpt/lib/libreadline.a -L /usr/lib/termcap -L/usr/lib64/termcap -ltermcap -lOpenFOAM -liberty -ldl -lm - o /home/sujunwei/OpenFOAM/OpenFOAM-1.4/applications/bin/linuxGcc4DPOpt/setSet /usr/bin/ld: cannot find -ltermcap collect2: ld returned 1 exit status make[3]: *** [/home/sujunwei/OpenFOAM/OpenFOAM-1.4/applications/bin/linuxGcc4DPO pt/setSet] error 1 make[3]: Leaving directory `/home/sujunwei/OpenFOAM/OpenFOAM-1.4/applications/ut ilities/mesh/manipulation/setSet/setSet' make[2]: *** [setSet] error 2 make[2]: Leaving directory `/home/sujunwei/OpenFOAM/OpenFOAM-1.4/applications/ut ilities/mesh/manipulation' make[1]: *** [manipulation] error 2 make[1]: Leaving directory `/home/sujunwei/OpenFOAM/OpenFOAM-1.4/applications/ut ilities/mesh' make: *** [mesh] error 2 would you give me some suggestion? Thanks |
Install the termcap package fr
Install the termcap package from an RPM. Go here[1] and choose your platform accordingly and download the relevant RPM file. If there is a termcap-devel package, install it as well. You can install (as root) using the following command 'rpm -Uvh package_name_goes_here.rpm'
[1] http://download.opensuse.org/distrib...t-source/suse/ NB: The correct thread for this post is on the OpenFOAM -> Installation section. |
ok Srinath, Thanks
now, it w
ok Srinath, Thanks
now, it works well |
