In the file "option" in the di
In the file "option" in the directories
$FOAM_UTILITIES/parallelProcessing/redistributeMeshPar/Make and $FOAM_UTILITIES/parallelProcessing/decomposePar/Make , EXE_INC variable have to include $(FOAM_UTILITIES)/parallelProcessing/decompositionMethods/decompositionMethod instead of $(FOAM_UTILITIES)/parallelProcessing/decompositionMethods/InInclude to be compiled successfully. Otherwise, "decompositionMethod.H" cannot be found and compilation failed. |
Line 4 in
$FOAM_UTILITIES/pa
Line 4 in
$FOAM_UTILITIES/parallelProcessing/Allmake should be (cd decompositionMethods: ./Allwmake) instead of (cd decompositionMethods: Allwmake) |
I cannot repeat your Make/opti
I cannot repeat your Make/options problem. Is the lnInclude/ directory missing in your installation?
Thanks for the './Allwmake' fix. |
Sorry.
I also could not repe
Sorry.
I also could not repeat the error that could not find the header file, decompositionMethod.H, after alteration to './Allwmake'. There is the lnInclude/ directory. Seems that './Allwmake' correction resolved the problem. |
