I've discovered the
I've discovered the following problem with foamLog when processing logs generated from interFoam. The result is a error message like this: Executing: awk -f ./settling_mg_initg/logs/foamLog.awk settling_mg_initg/log awk: ./settling_mg_initg/logs/foamLog.awk:10: MULES:Cnt=0 awk: ./settling_mg_initg/logs/foamLog.awk:10: ^ syntax error awk: ./settling_mg_initg/logs/foamLog.awk:11: MULES:FinalResCnt=0 awk: ./settling_mg_initg/logs/foamLog.awk:11: ^ syntax error awk: ./settling_mg_initg/logs/foamLog.awk:12: MULES:ItersCnt=0 awk: ./settling_mg_initg/logs/foamLog.awk:12: ^ syntax error Proposed solution: change the line Info<< "MULES: Solving for " << psi.name() << endl; to Info<< "MULES: Solving for " << psi.name() << "," << endl; in src/finiteVolume/lnInclude/MULESTemplates.C Greetings, Malte |
Another solution is to filter
Another solution is to filter out solver messages that don't include a ','
(cancelled posting to late ;-)
The attached file is a replacement for bin/foamLog http://www.cfd-online.com/OpenFOAM_D...hment_icon.gif foamLog |
| All times are GMT -4. The time now is 16:43. |
