-   OpenFOAM Bugs (http://www.cfd-online.com/Forums/openfoam-bugs/)
-   -   OpenFOAM 14 stock version parallel bug (http://www.cfd-online.com/Forums/openfoam-bugs/62583-openfoam-14-stock-version-parallel-bug.html)
msrinath80 May 30, 2007 03:59
Description: Running decompos
Description:
Running decomposePar when the controlDict has probe locations in it gives rise to warnings as shown below:
[madhavan@head02 icoFoam]$ decomposePar . cavity_parallel
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : decomposePar . cavity_parallel
Date : May 29 2007
Time : 01:33:05
Host : head02.cein.ualberta.ca
PID : 17797
Root : /amd/cein/homes/1/d/madhavan/OpenFOAM/madhavan-1.4/run/tutorials/icoFoam
Case : cavity_parallel
Nprocs : 1
Create time
Selecting function probes
Time = 0
Create mesh
Calculating distribution of cells
Selecting decompositionMethod metis
Finished decomposition in 0 s
Calculating original mesh data
Distributing cells to processors
Distributing faces to processors
Calculating processor boundary addressing
Distributing points to processors
Constructing processor meshes
--> FOAM Warning :
From function dlLibraryTable::open(const dictionary& dict, const word& libsEntry, const TablePtr tablePtr)
in file lnInclude/dlLibraryTableTemplates.C at line 67
library "libsampling.so" did not introduce any new entries
Processor 0
Number of cells = 199
Number of faces shared with processor 1 = 24
Number of processor patches = 1
Number of processor faces = 24
Number of boundary faces = 438
--> FOAM Warning :
Processor 1
Number of cells = 201
Number of faces shared with processor 0 = 24
Number of boundary faces = 442
Max number of processor patches = 1
Max number of faces between processors = 24
Processor 0: field transfer
--> FOAM Warning :
Processor 1: field transfer
--> FOAM Warning :
After running the case and reconstructing the stored times, when we run paraFoam, it crashes instantly.
Solver/Application:
icoFoam (but it could be just about any solver)
Source file:
libsampling.so?
Testcase:
Try the cavity tutorial in parallel. No special settings. Just remember to add some probelocations in controlDict.
Platform:
linux64
Version:
(OpenFOAM 1.4)
Notes:
Related forum thread: http://www.cfd-online.com/OpenFOAM_D...tml?1180511576
henry May 30, 2007 05:19
The best way to avoid these wa
The best way to avoid these warning messages is to remove the probes from controlDict while performing the decomposition. If you would rather not do this but would still like to avoid the warning message then remove lines 60-70 from OpenFOAM-1.4/src/OpenFOAM/db/dlLibraryTable/dlLibraryTableTemplates.C
and recompile.
Henry
msrinath80 May 30, 2007 14:47
Thanks for the prompt response
Thanks for the prompt response Henry. Much appreciated!
