Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Problem with icoDyMFoam tutorial
Old   April 24, 2007, 11:19
Default I just installed OpenFOAM-1.4
Mattias Liefvendahl
matlie is on a distinguished road
I just installed OpenFOAM-1.4 and tested the tutorials for icoFoam and oodles, which worked fine.
The tutorial for icoDyMFoam crashes however, see below for the error message.
The error seems to occur in the polyMesh::calcDirections function. Maybe it is the case/mesh/boundary conditions which are not set up correctly. They seem to be the same as the corresponding tutorials in versions 1.2 and 1.3, however. These tutorials work fine on my machine by the way.
checkMesh complains about skew faces, but that shouldn't cause this kind of crash.
This seems to be related to the thread by Joakim Möller about SetField.
So - what can be the problem ?
Regards,
Mattias
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : icoDyMFoam .. movingCone
Date : Apr 24 2007
Time : 17:18:13
Host : matlie
PID : 3240
Root : ..
Case : movingCone
Nprocs : 1
Create time
Create mesh
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: componentLaplacian
#0 Foam::error::printStack(Foam:stream&)
#1 Foam::sigFpe::sigFpeHandler(int)
#2 Uninterpreted: [0xffffe420]
#3 Foam::polyMesh::calcDirections() const
#4 Foam::polyMesh::directions() const
#5 Foam::polyMesh::nSolutionD() const
#6 Foam::polyMesh::nGeometricD() const
#7 Foam::twoDPointCorrector::twoDPointCorrector(Foam: :polyMesh const&)
#8 Foam::motionSolver::motionSolver(Foam::polyMesh const&)
#9 Foam::fvMotionSolver::fvMotionSolver(Foam::polyMes h const&)
#10 Foam::componentLaplacianFvMotionSolver::componentL aplacianFvMotionSolver(Foam::p olyMesh const&, Foam::Istream&)
#11 Foam::motionSolver::adddictionaryConstructorToTabl e<foam::componentlaplacianfvmo tionsolver>::New(Foam::polyMesh const&, Foam::Istream&)
#12 Foam::motionSolver::New(Foam::polyMesh const&)
#13 Foam::dynamicMotionSolverFvMesh::dynamicMotionSolv erFvMesh(Foam::IOobject const&)
#14 Foam::dynamicFvMesh::addIOobjectConstructorToTable <foam::dynamicmotionsolverfvme sh>::New(Foam::IOobject const&)
#15 Foam::dynamicFvMesh::New(Foam::IOobject const&)
#16 main
#17 __libc_start_main
#18 __gxx_personality_v0 at ../sysdeps/i386/elf/start.S:122
Floating exception (core dumped)
matlie is offline   Reply With Quote
Old   April 24, 2007, 15:49
Default Are you running single or doub
henry is on a distinguished road
Are you running single or double precision? If single try double.
henry is offline   Reply With Quote
Old   April 24, 2007, 16:01
Default There is a problem with calcDi
There is a problem with calcDirections for meshes in which all patches of type empty contain no faces, as is the case for this tutorial. One option is to change the patch type of the axis in the blockMeshDict file or change the logic in calcDirections in OpenFOAM-1.4/src/OpenFOAM/meshes/polyMesh/polyMesh.C by moving
nEmptyPatches++;
from line 66 to line 70, i.e. inside the
if (boundaryMesh()[patchi].size())
However, even after this change this case will still not run correctly single precision because the accumulation of error causes problems with the mesh motion.
Henry
Old   April 25, 2007, 09:14
Default Thanks Henry for the quick res
Mattias Liefvendahl
Thanks Henry for the quick response.
1. I am running in double precision.
2. I tried to change the patch type in blockMeshDict from 'empty' to 'patch'. It still didn't work (same error message).
3. I cannot try your suggestion of changing the code since I cannot recompile libOpenFOAM.so since the compiler cannot find 'demangle.h'. I saw that other people have had this problem. I couldn't fix it. I run Ubuntu 6.10.
Mattias
Old   April 25, 2007, 09:37
Default 2. I have changed the tutorial
2. I have changed the tutorial case so that it works without my suggested change to calcDirections:
movingCone.tbz2
Unpack using tar xjf movingCone.tbz2
3. I do not have any experience with Ubuntu Linux so cannot advise on how to install demangle.h.
Henry
Old   April 25, 2007, 13:15
Default Hi Mattias! I ran the tutor
lillberg's Avatar
Eric Lillberg
lillberg is on a distinguished road
Send a message via Skype™ to lillberg
Hi Mattias!
I ran the tutorial on my SuSE box without any trouble... are you running the 32 or 64-bit OF-version?
//Eric
lillberg is offline   Reply With Quote
Old   April 26, 2007, 03:53
Default Thanks Henry, Now movingCone
Mattias Liefvendahl
Thanks Henry,
Now movingCone case works.
Compared to 1.3, the execution is almost six times as fast!
Is that because of the finite volume mesh motion solver ?
Eric, I'm running the 32-bit version.
/Mattias
Old   April 26, 2007, 03:59
Default Yes the finite volume mesh mot
Yes the finite volume mesh motion solver is much faster. For me the difference was even larger on this case.
Henry
Old   April 26, 2007, 04:29
Default On large FSI cases using the l
lillberg's Avatar
Eric Lillberg
On large FSI cases using the laplacian solver with quadratic inverse distance diffusivity I found the fvMotionSolver to be about two times faster then the tetDecomp version. But then again I haven't look through all the code.
Is there some useful tuning for general 3D motion with preserved BL grids? Could you give a brief explanation on the different diffusivities.
Regards
/Eric
Old   April 26, 2007, 04:39
Default You may get significant perfor
You may get significant performance improvements on large problems by changing/tuning the solvers. The GAMG solver has a large number of parameters which if tuned carefully can give substantial benfits.
I implemented a large number of diffusivities for the fvMotionSolver but didn't have time to play with them much. It is also very easy to create new diffusivity functions for particular type of problems if the need arises. To preserve BL grids it might be useful to use a distance to the wall function to alter the diffusivity in that region. It would be very useful for all if you can play around with some of these options and let us know your findings.
Henry
Old   April 26, 2007, 04:51
Default I'll do my best ;-)
  #11
lillberg's Avatar
Eric Lillberg
I'll do my best ;-)
MovingCone tutorial and icoDyMFoam with addingremoving mesh layers idosil OpenFOAM Running, Solving & CFD 30 July 29, 2016 05:42
Mesh Problem with icoDyMFoam yuhai OpenFOAM Running, Solving & CFD 5 January 14, 2009 14:57
Problem with icoDyMFoam olivier OpenFOAM Running, Solving & CFD 13 December 19, 2008 09:03
Problem starting with icoDyMFoam kassiotis OpenFOAM Running, Solving & CFD 1 March 12, 2007 11:12
Problem with icoDyMFoam philippose OpenFOAM Running, Solving & CFD 19 March 7, 2007 12:06
