reconstructpar -region
I have a case which is first decomposed to 6 processors and then split into 3 regions.
The mesh is moving in all three regions, but the topology is constant. One region is called "plate". To reconstruct the case, I first run reconstructParMesh -region plate That reconstructs the mesh for plate in 0/plate/polyMesh. Then, when I try to reconstruct the fields, using reconstructPar -region plate it works fine for time 0 (as expected), but later for time 0.01 I get this error: -------------------------- Time = 0.01 cannot open file file: /home/workdisc/FIV2/Fall2/OpenFOAM/c2p4nw/processor0/0.01/plate/plate/polyMesh/points at line 0. From function regIOobject::readStream(const word&) in file db/regIOobject/regIOobjectRead.C at line 66. FOAM exiting --------------------------- The region name, "plate", is twice in the path. ? Therefore I removed "regionPrefix/" from line 220 in processorMeshes.C. Now reconstructPar "works", but maybe the reconstructed data is written on the original (undeformed) mesh from time step 0. Is the twofold occurrence of the region name in the path a bug? Have I got it right? What could you do instead? |
Sounds like a bug. Can you post a simple testcase?
Hi borrbyper,
your fix looks correct. The regionName is already the name of the mesh so will already be handled correctly 'under the hood'. thanks, Mattijs |
