Home > Forums > OpenFOAM Bugs
timeVaryingUniformFixedValue + dynamic mesh + OpenFOAM-1.5-dev
Old   June 19, 2009, 05:24
Default timeVaryingUniformFixedValue + dynamic mesh + OpenFOAM-1.5-dev
norman1981's Avatar
Norman Del Puppo
norman1981 is on a distinguished road
Dear OpenFOAM-1.5-dev developers,
I wasn't able to use the timeVaryingUniformFixedValue bc in a dynamic mesh case in the OpenFOAM-1.5-dev version, so I checked a little the code and I think there's a bug in the TimeVaryingUniformFixedValue header file and there's also something missed in the tetDecompositionFiniteElement folder...
I will post here my solution, now it's working for me, but as far as I don't know if I'm doing something nasty I'm kindly asking you to check it (I might be wrong ).
1- Open the ~/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/fields/PointPatchFields/derived/timeVaryingUniformFixedValue/TimeVaryingUniformFixedValuePointPatchField.H file
2- Go to line 74 and change
TypeName("oscillatingFixedValue");
with
TypeName("timeVaryingUniformFixedValue");
3- Go to the ~/OpenFOAM/OpenFOAM-1.5-dev/src/tetDecompositionFiniteElement/fields/tetPolyPatchFields/derived folder
4- Create a folder called timeVaryingUniformFixedValue
5- Go into the timeVaryingUniformFixedValue folder
6- Put the two attached files into this folder
7- Add:
$(derivedTetPolyPatchFields)/timeVaryingUniformFixedValue/timeVaryingUniformFixedValueTetPolyPatchFields.C
to the ~/OpenFOAM/OpenFOAM-1.5-dev/src/tetDecompositionFiniteElement/Make.cellDecomp/files file at line 126
8- Add:
to the ~/OpenFOAM/OpenFOAM-1.5-dev/src/tetDecompositionFiniteElement/Make.faceDecomp/files file at line 126
9- Go to the ~/OpenFOAM/OpenFOAM-1.5-dev/src/tetDecompositionFiniteElement folder and type ./Allwmake
Now everything should work
Regards
Norman
File Type: gz timeVaryingUniformFixedValueTetPolyPatchFields.tar.gz (1,017 Bytes, 15 views)
norman1981 is offline   Reply With Quote
Thread Tools
Trackbacks are On
How to set boundary layer of a moving body in GAMBIT to a mesh zone for dynamic mesh tomyangbath FLUENT 17 March 25, 2016 05:36
Problem with cyclic boundaries in Openfoam 1.5 fs82 OpenFOAM 36 January 7, 2015 01:31
dynamic mesh on a hexa grid Manoj Kumar FLUENT 4 August 8, 2010 08:28
dynamic mesh on a hexa grid Manoj Kumar FLUENT 0 August 21, 2007 07:41
Dynamic mesh + grid adapt = Crash! (Files included BillH FLUENT 4 July 24, 2007 15:31
