-   OpenFOAM Bugs (http://www.cfd-online.com/Forums/openfoam-bugs/)
-   -   SVN revision number in OF-1.5-dev (http://www.cfd-online.com/Forums/openfoam-bugs/65979-svn-revision-number-1-5-dev.html)
hannes July 2, 2009 08:39
in $WM_PROJECT_DIR/bin/foamVersion, the revision number is extracted by this command:
FOAM_DEV_SVN_REVISION_NUMBER=`$SVN_CMD info $WM_PROJECT_DIR | grep "Last Changed Rev:" | awk '{print $4}'`;
This only works, if english is selected as system language. With the following modification, the command would be independent from the selected language:
FOAM_DEV_SVN_REVISION_NUMBER=`LANG=en $SVN_CMD info $WM_PROJECT_DIR | grep "Last Changed Rev:" | awk '{print $4}'`;
Best regards, Hannes
mbeaudoin July 2, 2009 09:12
My bad...
I will modify this script so it will not be dependant on the locale settings.
Could you show me what is the output of the following command on your workstation:
svn info $WM_PROJECT_DIR
Thank you for your patience.
Martin
hannes July 2, 2009 09:21
Hello Martin,
it gives the following:
Pfad: /home/kroegeh/OpenFOAM/OpenFOAM-1.5-dev
URL: https://openfoam-extend.svn.sf.net/s...enFOAM-1.5-dev
Basis des Projektarchivs: https://openfoam-extend.svn.sf.net/s...penfoam-extend
UUID des Projektarchivs: e4e07f05-0c2f-0410-a05a-b8ba57e0c909
Revision: 1316
Knotentyp: Verzeichnis
Plan: normal
Letzter Autor: hjasak
Letzte geänderte Rev: 1315
Letztes Änderungsdatum: 2009-07-01 18:08:34 +0200 (Mi, 01. Jul 2009)
Regards, Hannes
mbeaudoin July 2, 2009 09:26
Hello Hannes,
Yep... silly mistake on my part... I will fix this right away.
Thanks to you and Jens Klostermann for reporting this.
Best regards
Martin
Originally Posted by hannes (Post 221228)
Hello Martin,
Revision: 1316
Plan: normal
Regards, Hannes
