July 9, 2009, 07:31 |
gradientEnthalpy and wallHeatTransfer
Markus Rehm
Rep Power: 17 |
I am having problems to use the gradientEnthalpy BC for buoyantSimpleFoam in the hotRoom case at the walls. For 0/T I applied it as follows: Code:
... fixedWalls { type gradientEnthalpy; gradient uniform -1000.0; } ... It doesn't seem to be a problem of the thermos - so much I found out. In gradientEnthalpyFvPatchScalarField.C:111 Tw.evaluate(); is calling its own updateCoeffs() function again and again. Any solution to this? I use the 1.5.x git version. See the output below. Regards, Markus. Code:
rem@IEC126:~/OpenFOAM/rem-1.5.x/run/buoyantSimpleFoam/hotRoom> buoyantSimpleFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5.x | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : buoyantSimpleFoam Date : Jul 09 2009 Time : 13:28:26 Host : IEC126 PID : 529 Case : /home/rem/OpenFOAM/rem-1.5.x/run/buoyantSimpleFoam/hotRoom nProcs : 1 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading environmentalProperties Reading thermophysical properties Selecting thermodynamics package hThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>> Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 0.85; alphah 1; alphak 1; alphaEps 0.76923; } Calculating field g.h Creating field pd Starting time loop Time = 1 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 8.16329e-07, No Iterations 6 DILUPBiCG: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 8.16329e-07, No Iterations 6 Speicherzugriffsfehler |
July 12, 2009, 14:05 |
Henrik Rusche
Rep Power: 18 |
Dear Markus,
The *Enthalpy-boundary conditions are not meant to be used on temperature-fields. You can understand the internal workings by having a look into $FOAM_SRC/thermophysicalModels/basic/lnInclude/basicThermo.C Try putting a fixedGradient boundary condition on T. Henrik |
July 13, 2009, 04:06 |
Markus Rehm
Rep Power: 17 |
Thanks Henrik,
I will have a deeper look. Markus |
