Home > Forums > OpenFOAM Bugs
ForceCoeffs in OF-1.6.x not giving coefficients
Old   August 25, 2009, 09:55
Default ForceCoeffs in OF-1.6.x not giving coefficients
Richard Samuel
rsamuel is on a distinguished road
Hi Foamers,
Has anyone had problems with forceCoeffs in OF-1.6.x ? I am using "type forceCoeffs" and have included the 2 new keywords, but when I run the case I get only standard non-Coeff force output - the headings are pressure/viscous, not Cd/Cl etc.
Richard
rsamuel is offline   Reply With Quote
Old   August 26, 2009, 02:48
henry is on a distinguished road
Thanks for letting us know. Actually you will find that only the header is inconsistent, the values should be the force coefficients not the forces. I will push a fix for the
header today.
H
henry is offline   Reply With Quote
Old   August 27, 2009, 03:47
Richard Samuel
Thanks Henry for your quick response. Yes indeeed it is only the headings that are incorrect - I should have recognised that the numbers looked strangely familiar .
Regards
Richard
Thread Tools
Trackbacks are On
Calculate aerodynamic coefficients with openfoam using only opensource programs Xwang OpenFOAM 20 May 20, 2016 11:26
lift and drag coefficients around a ground vehicle Pedro CFX 3 September 5, 2012 18:31
2D Flow over cylinder, low lift/drag coefficients olives03 FLUENT 1 February 11, 2011 19:05
Computing aerodynamic coefficients on bidimensional sections in 3D problems Aragon FLUENT 0 July 22, 2009 04:07
closure coefficients in 2-eq. turb. models Michael Main CFD Forum 2 December 8, 2003 13:15
