Home > Forums > OpenFOAM Bugs
Possible bug in reconstructPar with new BC
Old   September 30, 2009, 12:11
Unhappy Possible bug in reconstructPar with new BC
Flavio Galeazzo
flavio_galeazzo is on a distinguished road
Hello Foamers,
I am facing a problem using reconstructPar to reconstruct cases using a new developed BC. The new velocity BC is based on the turbulentInlet BC, having a reference field (vectorField), a fluctuation scale (vector) and some scalar parameters.
When I run the reconstructPar, it writes all parameters as expected, only the reference field is wrongly written as a scalarField with nonsense values.
I have tested versions 1.5.x and 1.6, the same problem appears.
Have someone an idea how to solve (or bypass) this problem?
flavio_galeazzo is offline   Reply With Quote
Old   October 1, 2009, 15:40
Mattijs Janssens
mattijs is on a distinguished road
Make sure you implement rmap and automap methods. Use any other fvPatchField that has a additional field, e.g. totalPressure.
mattijs is offline   Reply With Quote
Old   October 2, 2009, 04:33
Flavio Galeazzo
Hello Mattijs,
Thank you for the prompt reply. You were right, it was a problem with the automap and rmap methods. It is working well right now.
Thank you again!
Old   December 6, 2009, 18:13
Peter Wulf
peterW is on a distinguished road
it seems that I am facing a similar problem. I changed the inletOutlet fvPatch (from OF 1.6) by making the valueFraction() depending on a field value in the local patch cell. The new velocity BC works fine in serial and parallel computations.
However, when I have used it in parallel, I get the same problem as already described above with reconstructPar. I tried to use automap and rmap and I compiled the BC as part of the solver and alternatively as a dynamic library (is that necessary for reconstructPar?). But that did not change anything. When I set the name of the BC back to inletOutlet in all the processor directories reconstructPar works fine again.
Any ideas what I should look for or what I could have missed?
Thanks
Peter
peterW is offline   Reply With Quote
Old   December 7, 2009, 07:11
Mattijs Janssens
reconstructPar does not 'know' your boundary condition - it only knows the boundary conditions from the libraries it is linked with. In your system/controlDict add a
libs ("libYourLibrary.so")
to make it 'know' your boundary conditions.
Thread Tools
Trackbacks are On
reconstructPar --> fileName::stripInvalid() called for invalid fileName commandtouse adona058 OpenFOAM Bugs 23 July 1, 2016 10:16
Bug in reconstructPar david OpenFOAM Bugs 10 May 26, 2009 12:11
Problem with reconstructPar fabianpk OpenFOAM 5 August 14, 2007 09:17
Bug reports Mattijs Janssens (Mattijs) OpenFOAM 0 January 10, 2005 11:05
Forum y2k Bug Jonas Larsson Main CFD Forum 1 January 5, 2000 11:22
