Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
FaceCellWave.C: handleCyclicPatches() is called once for each cell
Old   October 22, 2009, 08:11
Default FaceCellWave.C: handleCyclicPatches() is called once for each cell
Tammo Wenterodt
wenterodt is on a distinguished road
Dear colleagues,
currently I am doing a research in turbulent plane channel flow using the kwSST_lowRe model from the extend-branch. I use a 1D grid, and for grid-independence studies I want to go to really high numbers of cells i.e. 1e3..1e5. While 1e3 cells are calculated quite fast, the larger grids are processed terribly slow, e.g. 2min for one outer iteration.
I tracked the problem down using valgrind/cachegrind which tells me, that most of the time is being spent in Foam::FaceCellWave<Foam::wallPoint>::handleCyclicP atches() and Foam::List<Foam::wallPoint>::List(int). The reason for this is that the check
if (hasCyclicPatches_)
// Transfer changed faces across cyclic halves
handleCyclicPatches();
is located within
Foam::label Foam::FaceCellWave<Type>::cellToFace()
const cellList& cells = mesh_.cells();
for
label changedCellI = 0;
changedCellI < nChangedCells_;
changedCellI++
so it is called once for each cell instead of once for each patch, causing the massive slowdown. Can anyone think of a better location for the transfer of changed faces?
Regards,
Tammo
wenterodt is offline   Reply With Quote
Old   October 24, 2009, 09:44
Mattijs Janssens
mattijs is on a distinguished road
The handleCyclicPatches call is outside the cell loop. Can you post a testcase for 1.6.x which exhibits this slowdown?
mattijs is offline   Reply With Quote
Old   October 26, 2009, 06:10
Red face Admitting I was wrong
Tammo Wenterodt
Seems like the slowdown actually comes from something else (I'll doublecheck my fvSolutionDict), sorry for bothering you guys.
The described problem only occurs at the initialization of the case (taking one second or so). The iterations are not affected. I came to the wrong conclusion when I checked with cachegrind, where I did only one iteration, and assumed that the slowdown came from the iteration-loop.
Regards,
Tammo
bug facecellwave
FvMatrix coefficients shrina OpenFOAM Running, Solving & CFD 10 October 3, 2013 14:38
reconstructParMesh not working with an axisymetric case francesco OpenFOAM Bugs 4 May 8, 2009 05:49
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Warning 097- AB Siemens 6 November 15, 2004 04:41
cell to cell relation CMB Siemens 1 December 4, 2003 04:05
