-   OpenFOAM Bugs (http://www.cfd-online.com/Forums/openfoam-bugs/)
-   -   applications/test (http://www.cfd-online.com/Forums/openfoam-bugs/70283-applications-test.html)
egp November 19, 2009 07:12
applications/test
Some of the tests in $WM_PROJECT_DIR/applications/test do not compile. They include the following:
CompactListList
DimensionedField
FixedList (compiles with 1.6, but not 1.5-dev)
LduMatrix (doesn't exist with 1.6)
ODETest
readCHEMKINIII (compiles with 1.6, but not 1.5-dev)
slicedFieldTest
volField
olesen November 20, 2009 04:04
CompactListList
DimensionedField
ODETest
slicedFieldTest
volField
Why worry about this? They aren't unit tests.
AFAIK they are used test out concepts, behaviour, etc. They probably aren't needed much later, but are useful to keep about for testing out new features.
henry November 20, 2009 06:40
Now fixed in OpenFOAM-1.6.x.
H
egp November 27, 2009 14:36
@henry: thank you.
@oleson: why distribute something that doesn't work? My approach would be to fix it, as Henry did, or to scrub it from the distro.
Eric
mbeaudoin November 27, 2009 15:27
Hello Eric,
They both compile now with 1.5-dev. Just update your local svn working copy.
I am not sure the test application readCHEMKINIII runs properly (not an expert here), but at least it compiles.
Originally Posted by egp (Post 237981)
@henry: thank you.
Eric
You are exactly right Eric. I don't think we have enough of those tests apps; so we should at least take care of the ones we have.
Best regards,
Martin
