Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
applications/test
Old   November 19, 2009, 06:12
Default applications/test
egp
egp's Avatar
Eric Paterson
egp is on a distinguished road
Some of the tests in $WM_PROJECT_DIR/applications/test do not compile. They include the following:
CompactListList
DimensionedField
FixedList (compiles with 1.6, but not 1.5-dev)
LduMatrix (doesn't exist with 1.6)
ODETest
readCHEMKINIII (compiles with 1.6, but not 1.5-dev)
slicedFieldTest
volField
egp is offline   Reply With Quote
Old   November 20, 2009, 03:04
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
CompactListList
DimensionedField
ODETest
slicedFieldTest
volField
Why worry about this? They aren't unit tests.
AFAIK they are used test out concepts, behaviour, etc. They probably aren't needed much later, but are useful to keep about for testing out new features.
olesen is offline   Reply With Quote
Old   November 20, 2009, 05:40
henry is on a distinguished road
Now fixed in OpenFOAM-1.6.x.
H
henry is offline   Reply With Quote
Old   November 27, 2009, 13:36
egp
egp's Avatar
Eric Paterson
@henry: thank you.
@oleson: why distribute something that doesn't work? My approach would be to fix it, as Henry did, or to scrub it from the distro.
Eric
Old   November 27, 2009, 14:27
Martin Beaudoin
mbeaudoin will become famous soon enough
Hello Eric,
They both compile now with 1.5-dev. Just update your local svn working copy.
I am not sure the test application readCHEMKINIII runs properly (not an expert here), but at least it compiles.
@henry: thank you.
Eric
You are exactly right Eric. I don't think we have enough of those tests apps; so we should at least take care of the ones we have.
Best regards,
Martin
mbeaudoin is offline   Reply With Quote
